KZ 650 Motor Swap Electrical
- AnthonyKiser1977
- AnthonyKiser1977
- loudhvx
- Thank you received: 1616
Those two go to the two yellows on the new reg/rec.What I have for wiring is as follows. Coming off of the 1978 motor, 2 yellow wires and
AnthonyKiser1977 wrote:
That wire comes from the neutral switch.1 green wire with a red stripe.
That is from the neutral light. That should connect to the neutral switch on the 78 motor (as mentioned above).Wiring still on the bike 1977, one green wire with red stripe coming off the bikes wiring harness.
The new reg/rec will connect to the black wire and the white wire. The three yellows should have gone down to the old 77 motor. If they are good, you can use two of the yellows to go to the two yellows on the new motor, or you can just run new yellow wires (preferred) and yank out those three old yellows.The old rectifier, which is located next the gas tank has 3 yellow wires, one black wire, and one white wire.
There should have also been a green wire which went down to the old 77 motor. You can leave these disconnected, but tape them up as the brown wire has battery voltage on it when the bike is on. (Remove the regulator, obviously.)The points regulator (1977) has one black with a yellow stripe wire, and one brown wire hooked up to it.
I'd appreciate it if OnkelB can confirm all of this, as I'm going from memory.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- OnkelB
- Thank you received: 80
77 KZ 650 B1, 82 GPz 1100 B2.
- AnthonyKiser1977
- AnthonyKiser1977
