Jammed Electric Starter?
- KZYoungBlood
31 Aug 2009 12:19 #317938
by KZYoungBlood
1981 KZ1000-J1
Replied by KZYoungBlood on topic Jammed Electric Starter?
mzandmz wrote:
give me a call or email:
email: ryan.knittel@gmail.com
phone: (818) 636-9524
I will take it off your hands and spend the 80 hours and $1000.00 to fix it. Just let me know when to show up at your house to rid you of the onging nightmare. :blink:
1981 KZ1000-J1
- KOOL RYDER
- KZ 650B2 / KZ 1000E
31 Aug 2009 15:38 #317998
by KOOL RYDER
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
Replied by KOOL RYDER on topic Jammed Electric Starter?
Have you checked the vaccume hose?
1978 KZ650B
1979 KZ1000ST
- mzandmz
31 Aug 2009 15:49 #318001
by mzandmz
New to Family, 1979 KZ440 LTD
Replied by mzandmz on topic Jammed Electric Starter?
I-800 pick up clunker. Here I am anytime .:dry:
- flht1997
- Thank you received: 2
31 Aug 2009 15:54 #318002
by flht1997
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
Replied by flht1997 on topic Jammed Electric Starter?
Is this a twin or a four? saying you looked under the side cover at the starter i am thinking a twin. it will be a battle to get a good working electric starter. if you have a kick starter worry about the electric later. i really would not worry about what it will run like now. the bike sounds neglected. take the carbs off clean them, clean the ignition advance and set the points, put new plugs in it, change the oil and put new gas in it then see what it does. after it is running for awhile, check the valve clearance and balance and tune the carbs.
Matt Milwaukee, WI
89' BMW R100RT
06' KLR650
- mzandmz
31 Aug 2009 19:18 #318069
by mzandmz
Sounds like you'll get her fixed up soon. It will start. There enough help out here to get it going. My fingers are crossed for you. Hang in there. Think possitive like the train that could. Good luck to you
