- Thank you received: 6
Electrical Connector Help
- grumpy56
1) How do I remove the spades and connectors in the old connector (2.8mm I think) without damaging them? Would like to use many of the existing ones if I can. Is there a tool for this?
2) I assume there is some trick to inserting the new hardware into the connector.
3) I don't have alot of slack in the harness, so any help to ensure I don't screw it up and have to add wire is appreciated.
4) Do the dealers have these plastic connectors or should I just order on-line?
Thanks.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1972 Suzuki GT380 (In-Process)
In The Past...71 TM400, 72 H-D SS350, 72 GT380, 75 Z1B, 77 XLH, 79 CB750K
- arai59
- Banned
- Thank you received: 1
- MFolks
- Thank you received: 540
- grumpy56
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- Thank you received: 2098
I think Jeff at Z1 might have those connectors. That or he can tell you where to get one. I did the same thing once. Use a jeweres tool. You can finnd a set of tiny flat blade screw drivers anywhere. (ie. harbor freight) There is a tab that can be depressed from the terminal side. Just slide the tool in and gently remove the terminal. Once you get one out and see the rest go easy. Make sure you diagram the color layout first so you know where to install them again. After removing the terminal slightly raise the tab again before you insert it into the new connector. It's like a small spring tab which you'll see once removed.
Click on these links for listings at Z1E:
Connectors
More connectors
Yet more connectore
Connector Pin Extractor Tool
Good Luck!
EDIT PREVIOUS POST
Click on this link, then look at pages 2, 3 and 4 for electrical connector listings at Z1E:
See connectors on pages 2, 3 and 4
Good Luck!
EDIT #2 to PREVIOUS POST
And here's a link to Z1E's Connector Pin Extractor Tool
Good Luck!
- grumpy56
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- Thank you received: 2829
HVCCYCLE
- bountyhunter
- Thank you received: 337
EDIT PREVIOUS POST
Did there used to be an EDIT function here or is my memory slipping?
- grumpy56
Patton: Nope, I think your memory is moi bueno.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- arai59
- Banned
EDIT PREVIOUS POST
Yes but some abused it to throw sand in others faces then as I heard all were punished. The man has taken charge. Kinda reminds me of a line in the great movie " Cool hand Luke".........what we have here is........failure to commuinate....some men you just can't reach.
www.entertonement.com/collections/4376/Paul-Newman
