coil mod / hidden kill switch
- cary
12 Mar 2006 17:04
Just did wiredgeorge's coil mod last week... the relay kit I bought from O'Reilly auto had all the wiring, a fuse holder, and a switch. After wiring everything up and testing it, I went ahead and put the included switch on the relay switch line and attached it in a hidden spot.
With the switch in the off position, the lights come on, and the starter works, but there is no power to the coils, hence, no running. I figure if I ever park somewhere shady, this will deter the average hooligan with a flathead trying to joyride my scoot.
Anyone else try this on their bike, I soldered the switch in, is there any concern that it may corrode or otherwise mess up the bike?
- wireman
Re: coil mod / hidden kill switch
12 Mar 2006 17:10
soldering beats crimp connects anytime disassembly isnt regularly required!remember to use acid core solder.i use the neutral safety switch wiring as a kill switch and mount a toggle switch under tank or under seat where i know where it is,even with the key you cant start it without knowing where switch is at.:whistle: goodluck,happy wrenching!
- rstnick
12 Mar 2006 19:00
Cary, which wire did you put the switch onto? The one that feeds the coils from lug 87? I guess you could probablly put it on wire 87, 86 or 36 and it would cut Ign. power.
Did you tape or shrink wrap after you soldered? Then you should be fine.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- TonyKZ1
13 Mar 2006 06:15
You don't want to use acid core, that's used on copper pipes, etc. for plumbing. What you want to use is resin-core, that's normal for electronic circuit use.
Sounds like the switch ought to work very well for a theft deterrent, but of course don't forget about it and then run your battery down trying to get it started.
Tony
Tony
1997 Yamaha Seca II - mostly stock, Oxford Heaterz heated grips, a Scottoiler system. My
Mileage Tracker Page
- wireman
13 Mar 2006 08:23
acid core used for plumbing?thats new to me .ive always used Stay Brite 8,or Bridgit for plumbing or silver solder for big stuff.in my book acid core and rosin core solder are the same thing ,self fluxing solder.
- cary
13 Mar 2006 10:56
I used rosin solder and wired my kill switch to the #86 trigger line.... If I ever forget that I've left my kill switch off and can't start the bike, chanes are I'm in no condition to ride anyway :blink:
- BARNEYHYPHEN
13 Mar 2006 13:39
Just my $0.02 worth but I agree with the switch going into the #86 line. I thought the whole point of the relay is due to the juice going down the #87 line?
Hey Cary, I can understand you wanting as many antitheft devices as you can muster, living in the 'boro.
- Nevco48
13 Mar 2006 14:00
cary wrote:
Hey, you could be onto something. Like those breath tester things drunks got to blow in before their car will start... If you can't find the switch(es), then you had better walk home.:silly:
- N0NB
- Blue handles better
13 Mar 2006 14:22
The switch could be inline with either of the 86 legs as an open on either one will keep the relay from operating. Generally, a switch inline with the 86 leg from the kill switch would probably be prefered.
However, if someone knows this circuit were installed on a bike, the switch can be bypassed by shorting out the relay from pins 36 to 87. So, a hidden switch in the 36 line might be the most secure.
The safest in terms of safety from a short circuit of the switch or its contacts to the frame would be in the ground leg of the other 86 pin. The worst a short would do here is keep the relay energized.
I guess I ought to shutup and stop confusing the issue. :silly:
- Nate >>
- Nate >>
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel
- loudhvx
13 Mar 2006 22:56
The trick is to re-wire the bike using only one color wire.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- modest911
14 Mar 2006 04:20
I got that trick nailed! haha - I started this project and found that there are differents AMP relays at NAPA - What rated amps is everyone else using?
loudhvx wrote:
- tw..
14 Mar 2006 06:06
I've been hearing a lot of positive things about doing the coil mod. Would i see any benefit if i did the coil mod on a bike with a Dyna S ignition and Dyna coils?
tw
tw
2-1976 KZ900 A4
1995 KZ1000 Police bike
1978 Z1R
1978 Z1R
