Sudden loss of power then fuse blows? Help please
- BARNEYHYPHEN
Re: Sudden loss of power then fuse blows? Help please
18 Jun 2009 14:31
Thanks for the suggestion Loud. I'm going to give that a bash tonight. Will report back.
BH
BH
18 Jun 2009 18:43
BARNEYHYPHEN wrote:
F mark should align with case mark at idle rpm (1200 rpm or less). Same as points system.
Good Luck!
...advance mechanism seems to get the timing fully to the "F" mark around 2,000 RPM. The two springs appear to be tight and not stretched. Can the advance mechanism springs lose their "pull" over time, even though they don't appear to be stretched? Where can we obtain correct new springs?
Good Luck!
- loudhvx
18 Jun 2009 21:17
Yeah, good point Patton. The F mark is for idle. On the 550's, at least, the full advance is between two scribe lines. I was referring to adjusting the springs so the timing doesn't reach the two scribe lines too early.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- BARNEYHYPHEN
19 Jun 2009 11:16
F mark at idle. Thanks. For some reason I was thinking T at idle, F at 2,500 RPM? That may be my problem (a little rough right now). #3 pot somewhat hit & miss (more miss than hit).
Springs wer a touch slack so I followed Loud's suggestion to tighten. Worked extremely well. Did however notice that the large "slip washer" that sits between the base of the Dyna rotor, and the base plate of the advance unit mechanism, was a touch worn on one side, so flipped it over. BUT, for those who care, the washer was a little "cupped" due to the years of wear on one side and, when flipped over, due to the cupping, it held the rotor too tight against the center retaining nut/bolt. Thereby causing binding. Decided to remove the washer all together. No more binding.
Will re-time this evening and report back. Thanks.
BH
BH
- BARNEYHYPHEN
22 Jun 2009 10:55
Well, what a difference two new coils and a new Dyna S make! Like a new bike. Thought it was running well before but hadn't realized how much better it could be.
Starts from cold or hot at one very short dib of the button and runs very strong, without missing a single beat, through 7,000+. probably would go well beyond 7,000 but I just don't want to ask it of a 33 yr old.
Thanks again to Patton for the "F" mark reminder for the dynamic timing.
BH
BH
