Keep blowing headlights
  • larrycavan
  • larrycavan's Avatar
Re: Keep blowing headlights
28 Mar 2009 06:43
#276021
Seems to me the problem is there is more advice than acutal problem.......;) Here's some more :ohmy:
Think about it.... Check the charging system output. It's either in or out of the range. That has to be resolved before any other guessing / theory is worth looking into.
  • Old Man Rock
  • Old Man Rock's Avatar
28 Mar 2009 06:58
#276026
@ Tony... DOH!... Me so sorry....
Harbor Freight Tools.... I had to buy a new Tach and came across this one where it has Tach, Dwell, Capacitance and all the other normal DVM functions...
For those of you still using non EI, this is perfect for ya for checking those nasty little condensers... ;)
In either case, as Larry and some of the others pointed out, you need to insure your charging circuit is working so you must either purchase at least a volt meter of one sort or another to confirm...
Pretty much a voltmeter with continuity (resistance) measurements can be found anywhere in your local area.
Hardware or automotive stores all carry them...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • Zacknhs
  • Zacknhs's Avatar Topic Author
28 Mar 2009 19:20
#276204
i found all three of my multimeters. i knew i had them somewhere i'm a aerospace engineering student that dose all of his own auto work. the bike is sitting here in parts waiting for another reshipment from Z1. once it's here on monday i will put it back together and check the charging system.
i saw the post about the colors of the bulb. it is always clear just the filament is broken. -> so vibration. still going to check the charging system to be safe.
if it's vibration Rice Paddy is 2 blocks from me hopefully they have the bucket grommets for less then a arm and a leg.
Columbus, Ohio
Go Bucks
1978 Kz1000 <- first bike and i love it!!
  • bountyhunter
  • bountyhunter's Avatar
29 Mar 2009 13:27
#276441
If the system is seeing excessive voltage, the SMALLER bulbs usually blow first because they can't handle the power well. On mine, the instrument light bulbs blow first. Headlights are a lot more resistant to over voltage than the small bulbs.
Headlights are notorious for dying due to vibration.
  • otakar
  • otakar's Avatar
29 Mar 2009 18:44 - 29 Mar 2009 18:49
#276560
Do like I did go with HID Xenon and you do not have to worry about voltage (it is good to 16v) or a bulb filament for that matter. Here is mine.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 29 Mar 2009 18:49 by otakar.
  • otakar
  • otakar's Avatar
29 Mar 2009 18:46
#276562
This is what it looks like on the bike.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
  • otakar's Avatar
29 Mar 2009 18:47
#276566
This is what it looks like ON. :woohoo:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
  • otakar's Avatar
29 Mar 2009 19:26
#276593
Here's the light it puts out.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • Zacknhs
31 Mar 2009 05:48
#276973
i forgot to mention that i did have a hid in it at one time and the filament in it became broken also after about a month. the bike will be running today. got the carbs and tank back on yesterday. just need to put gas in and sync the carbs. then I'll check with the multimeter. i have been looking in to high vibration h4 bulbs. if it's not voltage too high then i'll try one of those.
Columbus, Ohio
Go Bucks
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
31 Mar 2009 08:05
#276999
Been there,done that...blew those type as well.
I think I went through 3 of that style,before rectifying the vibration issue.
They DID last longer,but they did blow.B)
1977 KZ1000 A-1
  • Zacknhs
01 Apr 2009 20:18
#277555
so i got the bike out today. the electrical system checked out ok.
so vibration is my problem. i noticed on the way back from bike night that my head light bounces around as i ride i need to check out the bucket grommets before i make my order at z1 for jets.
Columbus, Ohio
Go Bucks
  • saxjonz
  • saxjonz's Avatar
  • KawboyZ
03 Apr 2009 13:09
#278098
otakar, that is a nice jag in the drive and the paint on your bike.... very nice. Hope to ride with you soon. I am still waiting on the machine shope to finish my parts.
79 LTD B3
