name this elec part...please
  • loudhvx
  • loudhvx's Avatar
Re: name this elec part...please
24 Feb 2009 11:28 - 24 Feb 2009 11:29
#267792
Yes, the combo units from Z1 are the way to go. I didn't look at the difference between the two that Patton listed. Is it just a connector difference? or is there a difference in the wiring?
But the combo reg/rec allows you to eliminate the seperate reg and rec units. I just don't know how plug-n-play they are (for mounting etc.). Someone will chime in.
Last edit: 24 Feb 2009 11:29 by loudhvx.
  • trianglelaguna
  • trianglelaguna's Avatar Topic Author
24 Feb 2009 11:36
#267794
one of the ones patton so kindly linked em with shows the axact green connector...that should be cool ...i just gotta learn what /how the stator hooks thru the panel and see what the white plug will get dropped???loudhvx wrote:
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
24 Feb 2009 12:17
#267803
Whereas the $90.72 version doesn't have the connectors and requires wire splicing, here's the $108.99 version which includes connectors for an easier installation. The biggest problem I recall was having difficulty holding the unit in position under the battery box and keeping the holes aligned while getting the attachment screws started.
Rectifier/Regulator Combination Unit KZ1000 KZ900
PM81-4081
OEM: 21066-025 99996-1159 21061-024
Bolt-on replacement for the stock regulator & rectifier. Solves the problem of overcharging batteries. Simple to install - NO CUTTING OR SPLICING OF WIRES. Fits Kawasaki KZ1000 (77-78) KZ900 (76-77)
You will need slightly longer mounting bolts as the new unit is a little deeper. Remove the existing regulator & rectifier taking care with the bullet connectors. Bolt this new unit in the place of the old regulator (under the battery box). Plug the green connector into the electrical panel, connect the ground wire to the engine ground point (behind the kickstarter), connect the one wires normally going to the rectifier into the double female connector on this new unit and you are done...
Good Luck! :)
  • Bluemeanie
  • Bluemeanie's Avatar
25 Feb 2009 05:12
#267981
trianglelaguna wrote:
thanks and the prize for the correct answer is a red bull 2009 moto gp decal.....
Sooooo, did anyone walk away with a new decal?? :blink:
  • H2RICK
  • H2RICK's Avatar
  • Is this a fun bike, or what!!!
25 Feb 2009 18:15
#268119
TL, that last pic of yours of the genuine NOS Kwak item is definitely a regulator ONLY...
it needs a separate rectifier unit to work properly.
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
  • trianglelaguna
25 Feb 2009 18:41
#268129
k just a reference pic...folks mis-list em as dual rec/reg on sicbay all the time and can teach a guy bad info...thanks
1976 KZ900
2003 ZX12R
2007 FZ1000
  • trianglelaguna
25 Feb 2009 18:45
#268131
ANYONE WHO WANTS A MOTOGP DECAL...can pm me and i'll send em one or two free i got a stack and they are cool..redbull mazda/laguna seca 2009 mtogp 3x5"
1976 KZ900
2003 ZX12R
2007 FZ1000
