MKII turn signal hook up. stock tail light
- Captaingamez
08 Feb 2009 10:26
the stock tail light on my MKII is a dual bulb, it has one on the right and one on the left. what would i have to do to make the right and left side of my tail light operate as turn signals while still retaining my brake light functions and such.
1979 Kz1000 MKII road racer project
1994 Seca II, pile in the corner
1973 Honda cb175 cafe racer
1971 Yamaha AT1
1975 Massey Fergusson MF440
1971 Skiroule 300rr
1971 Yamaha AT1
1971 Skiroule 300rr
- MFolks
Re: MKII turn signal hook up. stock tail light
08 Feb 2009 14:11
It does not apear to be easy to do as the bulb sockets are welded/bonded together sharing the ground. Look at
www.jpcycles.com
and
www.denniskirk.com
for a electronic tail light circuit devise.
- Captaingamez
08 Feb 2009 21:45
i figured it out . i ran a trailer adapter for a truck, the o ne i used was a 5 wire to 4 wire converter. it was pretty easy and its all hidden in the tail section very easily. ill post a pic tomorrow.
1971 Yamaha AT1
1971 Skiroule 300rr
1971 Yamaha AT1
1971 Skiroule 300rr
- 79MKII
- Love Them Kaws!
09 Feb 2009 18:20
I see I'm too late to help, but you figured it out. A simple tail light converter is all you need. I bought a new one for around $15 after returning a much more expensive unit built specifically for motorcycles that cost nearly $100!:ohmy: I ended up going with small turn signals after all, but I think the dual bulb tail lights will work just fine.
What I really wanted to do was convert the bulbs to dual color led's so they'd be red and then turn yellow when the turn signal was on. That would be awesome with a clear lens. Never got that figured out...
The Kaw List:
- wiredgeorge
10 Feb 2009 04:43
I am not sure how good an idea this is anyway. If you have the tail lights blinking for turns, keep in mind they are VERY close together and VERY close to the center of the bike. Will a driver behind be able to interpret them?
- 79MKII
- Love Them Kaws!
10 Feb 2009 04:47
That was a definite concern of mine too. It did seem to look pretty obvious though, but it's still hard to tell what a driver behind you would think, especially during the day when it would be even harder to see the lights.
The newer integrators are multicolored and some even have arrows that flash sequentially. Those would work much better.
The Kaw List:
- 79MKII
- Love Them Kaws!
10 Feb 2009 04:56 - 10 Feb 2009 05:03
The Kaw List:
Last edit: 10 Feb 2009 05:03 by 79MKII.
- 79MKII
- Love Them Kaws!
10 Feb 2009 05:02
Here's another attempt to post the actual picture - had it working in the previous post - edited something else and now the picture won't work??!!
The Kaw List:
- Captaingamez
10 Feb 2009 08:30
the visibility issue is one of my concerns, i am going to make some alterations to the light itself, which would be easier if i could find some LED lights that plug into regular light sockets, do they make them? i thought of putting arrows maybe.
1971 Yamaha AT1
1971 Skiroule 300rr
1971 Yamaha AT1
1971 Skiroule 300rr
- wiredgeorge
10 Feb 2009 12:12
If I were following that sportbike with the annoying taillight blinking, I wouldn't have any idea that it meant turn signal. I think the safest turn signal is a larger one, mounted as far apart as possible. I bought some replica KZ1000R (ELR Replica) turn signals from
www.z1enterprises.com
and they look pretty nice. The front signals can come in either running light type or non-running light. I got the running light (bulb has two filaments).
79MKII wrote:
- MFolks
10 Feb 2009 12:37
www.hyperlites.com
has some and an article on
www.webbike
world.com covered brake lights.
- Captaingamez
10 Feb 2009 15:07
the turnsignals are actually very visible. i tested it out today. i had two people follow me and tell me what they thought. they both said it was easy to tell what direction i was going from a safe distance.
1971 Yamaha AT1
1971 Skiroule 300rr
1971 Yamaha AT1
1971 Skiroule 300rr
