The Dreaded Intermittent Electrical Problem!
  • ZappBranigan
  • ZappBranigan's Avatar Topic Author
Re: The Dreaded Intermittent Electrical Problem!
30 Dec 2008 09:20
#255360
Thanks for all the input. Once it's warmed up and I have a little bit of time I'll tackle it. I like the idea of the fuse box substitution, if that can fix the problem, I'll be golden.
Is there a replacement fuse box that will fit in place of the original?
"When I'm in command, Every mission is a suicide mission!" - Zapp Branigan
82 KZ750N1 (Spectre)
24k Miles
  • OKC_Kent
  • OKC_Kent's Avatar
30 Dec 2008 12:52
#255392
The ATO/ATC blocks are small, and can fit in the same area as the stock fuse box. You may have to screw it down to something.
Look here, order.waytekwire.com/productdetail/M37/46080
If you go in the catalog there are more to choose from. These can also be found at auto supply stores, maybe Radio Shack. I think the easiest way is to go with the red and black deal a few posts up.
Cashion, OK
78 KZ650 B2 85,000+ miles
  • bill_wilcox100
  • bill_wilcox100's Avatar
30 Dec 2008 16:19 - 30 Dec 2008 16:25
#255433
ZappBranigan, if you’re up for a project here is a little circuit I added to my fuse box. It turns on a LED next to the fuse that's blown... not bad for night failure.
Best of success. :)
PS
If you want the assumptions and calculations check out my Photobucket site:
Fuse Box Upgrade - LED's
Bill
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Last edit: 30 Dec 2008 16:25 by bill_wilcox100.
  • jona
  • jona's Avatar
30 Dec 2008 16:42
#255438
On these older bikes a lot of the problems are electrical connections, clean and reconnect. Replace fuses with a main fuse block; i.e. P/N AF-CFB4 from www.wiringproducts.com . Plus everthing thing these guys have said: follow wires-dielectric grease........Good luck. jona.
