Toggle to replace key ignition switch
  • clutch
  • clutch's Avatar Topic Author
  • I wish I had a tad more patience to do it better!
10 Nov 2008 21:25
#246747
Hey guys,
I'm considering replacing my key ignition switch with a toggle switch. I understand that their is a certain risk in doing so, but was wondering if anyone has done this on a kz. It looks like I will actually need two switches to do it correctly....anyone?
~Clutch
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I say more?)
The following user(s) said Thank You: KZ Kicker
  • donthekawguy
  • donthekawguy's Avatar
Re: Toggle to replace key ignition switch
10 Nov 2008 22:47
#246751
I had one on my 900 years ago. I can't remember how I wired it up but I was 20 years old so if I could figure it out then, anyone should be able to figure it out now. :laugh: I think it went something like one wire to one plug on the back of the switch and three wires to the other. It is pretty easy.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • Old Man Rock
  • Old Man Rock's Avatar
11 Nov 2008 04:35 - 11 Nov 2008 04:36
#246766
We would require the electrical schematic to tell you what would be required for the switch usually accomplishes more than one function.
Same time, why would you even want to do this?
On a drag or racing bike I'd totally understand but on a street bike... :huh:
Anyone have a schematic for his bike (1980 KZ250)?
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 11 Nov 2008 04:36 by Old Man Rock.
  • clutch
11 Nov 2008 08:23 - 11 Nov 2008 08:24
#246799
Like I said, I'm thinking about it, and understand the risk. IF I do it, I will hide the switches somewhere less obvious than the gauge cluster/handlebar area. Here is the schematic you wanted:
Don't ask me what park is....I only have ON and OFF on my switch!!
Wish List:
Last edit: 11 Nov 2008 08:24 by clutch.
  • mariozappa
  • mariozappa's Avatar
11 Nov 2008 08:32
#246803
PARK is the far right position of the key, 1 click past ON.
It turns on the tail light if you have parked on the side of the road for (1980) safety.
1977 KZ650C1
and the KZ650/KZ750 Conversion ;)
  • clutch
11 Nov 2008 08:34
#246804
OH! That's kinda cool, but I'm pretty sure mine is only a two position switch...will check it out later...
Wish List:
  • Old Man Rock
11 Nov 2008 10:16
#246821
1 single pole double throw switch is all you need then... Switch White to Brown and switch Blue to Red...
or two single pole single throw switches, one for each.
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • MFolks
  • MFolks's Avatar
11 Nov 2008 11:04
#246827
If you want to make it difficult to steal, have several switches with dummy wires with the same color code scattered around the bike. Or more than one toggle switch in the ignition circuit only wired backwards(I.E. off for on).
  • clutch
11 Nov 2008 11:12
#246830
That is the main reason I'm not sure I want to do the toggle switch. Though it would be simple for me to wire a hidden battery cutoff switch to increase security...
Wish List:
  • mariozappa
11 Nov 2008 11:35
#246835
If you want to make it difficult to steal...
Trust me, if they WANT it they will TAKE it!
1977 KZ650C1
  • MFolks
  • MFolks's Avatar
11 Nov 2008 12:29
#246842
To throw a potential thief another problem is get a surplus Mil-Spec water resistant rotary switch with 6-8 positions and wire several toggle switches in line with it. The only way then to take it would be to pick it up.
  • clutch
11 Nov 2008 12:53
#246845
I COMPLETELY agree with this statement. No matter what it has for security, someone that wants it bad enough, will find a way around it and take the bike...
Wish List:
