Dyna S and OEM coils for now.
- HerrDeacon
Re: Dyna S and OEM coils for now.
05 Nov 2008 15:55
Thanks for the write up and pics bill. I'll be adding a Dyna as well over the winter and this will come in handy. Thanks.
- 78z1Joe
- My man cave is my garage....
05 Nov 2008 18:58
About 20 years ago, I put a Dyna S ignition and Accel coils ( yellow ones) on my KZ and have not have any problems. The only thing I remember from back then was that the bike started quicker that before which I think had more to do with the new coils with a hotter spark compared to the old stock ones. The point I'm making is that the combo of the two is worth it.
PS The coils did come with yellow 9mm wires which did look neat.
1978 KZ 1000
1982 GS 300 training bike
Previous Rides...
75 RD 350
72 CB 500 Four
72 SL 125
71 CT 70
69 3 1/2 HP mini bike
Previous Rides...
75 RD 350
72 CB 500 Four
72 SL 125
71 CT 70
- bountyhunter
05 Nov 2008 22:57
78z1Joe wrote:
The elect modules usually have a switching converter inside that bumps the primary voltage up. When you crank a stock ignition with the starter, the battery voltage sags and the spark voltage drops too. In electronic based systems they usually don't have that problem, so the spark is just as hot cranking as it is running.
- 650mod
14 May 2013 19:47
+1, definitely keeping this info for when I convert
78 kz 650 custom
Wiseco 720cc big bore
Dynajet stage 3 carb kit with pods
2002 Kawasaki Z750 exhaust
2001 Buell lightning front end
1999 Ninja 600 swingarm with 1999 Ninja 900 rear rim
converted to monoshock rear
Too many goodies to list fully
- bill_wilcox100
15 May 2013 08:51
650mod: "+1, definitely keeping this info for when I convert"
Keep us up to date and pictures are always appreciated.
Best of success,
Bill
Best of success,
Bill
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Upgrades:
Montreal, Canada
- lightitup
15 May 2013 09:05
what about dyna green coils with oem ignition?? would it work i have a pair coming in the mail.
81 kz 550 ltd
- 650mod
15 May 2013 10:37bill_wilcox100 wrote: 650mod: "+1, definitely keeping this info for when I convert"
Best of success,
Bill
Bill- I absolutely will. I'm currently in the middle of a front/rear end conversion on my 650. 2001 Buell Lightning X1 front end, 1999 Ninja 900 rear end. Here's my build:
kzrider.com/forum/11-projects/573616-650...ld?limit=20&start=20
I really like how detailed you went with your Dyna swap- I'll definitely be following suit on this one. I've had tough cold starts for a bit, so I've tuned the carbs up again, and figured a good Dyna would also help.
Devin
78 kz 650 custom
- bill_wilcox100
15 May 2013 20:00650mod wrote:bill_wilcox100 wrote: 650mod: "+1, definitely keeping this info for when I convert"
Best of success,
Bill
Devin
For a few more KZ650 Mod/Maintenance diagrams/write ups you may find my PhotoBucket pages useful:
s259.photobucket.com/user/bill_wilcox100/library/?sort=3&page=0
Best of success,
Bill
Upgrades:
Montreal, Canada
Upgrades:
Montreal, Canada
- loudhvx
15 May 2013 21:493-ohm green Dyna coils should work fine with the OEM electronic ignition.lightitup wrote: what about dyna green coils with oem ignition?? would it work i have a pair coming in the mail.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- 650mod
15 May 2013 23:11
Bill,
your photo bucket is a wealth of info- thank you SO much for linking that up. I need to set my float levels to endure I won't have any more issues- I now know exactly where I'm going with this!
Devin
Devin
78 kz 650 custom
- bill_wilcox100
16 May 2013 10:59
650Mod, You're welcome. IMHO, the KZ650 has an undeserved reputation as being difficult to start. When I first got mine that was also the case. I needed full choke, lots of cranking and after starting a lot of warm up time before it was driveable.
Over time and only with the knowledge, help and support of the KZRiders here I started to take control of my bikes maintenance. Now I know to a certainty that it was all the fault of incompetent maintenance by the previous owners… and me. I have seen that with proper adjustments in the proper ORDER the KZ650 can start on first crank every time and run as smooth as a sewing machine.
Somewhere here there is a rather long, complete and SEQUENTIAL procedure as to what to do FIRST all the way to what to do LAST… it makes all the difference!
BTW if you have poor contacts in you handlebar switch gear change them now… or if like me you just can’t afford it now then do the less expensive (<$10.00) Coil Repowering Mod first… it saved my bike… true not all here will agree but that’s democracy for ya.
Can anyone out there pull up that step-by-step procedure for 650Mod and repost it here. There is also one on how to troubleshoot shorts circuits and open circuits that has that same step-by-step approach… again if anyone can repost that here it would be great.
Best of success,
Bill
Best of success,
Bill
Upgrades:
Montreal, Canada
Upgrades:
Montreal, Canada
- 650mod
16 May 2013 11:43
Bill,
Handlebar gear switch gear? What do you mean here?
Devin
Devin
78 kz 650 custom
