Did a search, no relevant answers. . .
  • KaZooCruiser
  • KaZooCruiser's Avatar Topic Author
31 Oct 2008 14:51
#244831
Search was "fuel light"
Problem is the thing comes on and goes off at random intervals.
Tank can be full, empty, or anywhere in between.
All i know for sure is that the light works.
Too well.
KZ650 '78
Thanks in advance.
  • ronjones
  • ronjones's Avatar
Re: Did a search, no relevant answers. . .
31 Oct 2008 15:16
#244837
Just a thought but I'd look @ either the sending unit or a short to ground in wiring.
  • flht1997
  • flht1997's Avatar
31 Oct 2008 15:35
#244839
78' 650 has a fuel light???
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
  • HerrDeacon
  • HerrDeacon's Avatar
31 Oct 2008 17:05
#244852
Yeah, my '78 has the light in the tach, but my bike doesn't have the sending unit. Tank was swapped by previous owner.
Regarding the problem, seems like there may be a loose wire, or a sending unit issue.
  • rstnick
  • rstnick's Avatar
31 Oct 2008 18:49
#244873
D models have a light.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s (aka GPz750)
1978 KZ1000 project
  • flht1997
  • flht1997's Avatar
31 Oct 2008 19:00
#244876
learn something everyday, i have a B model. i would look for a wire either shorting to ground or becoming open, if it is a light with no gauge it should be pretty simple to figure out.
Matt Milwaukee, WI
89' BMW R100RT
06' KLR650
02 Nov 2008 14:34
#245204
Geeez, a fuel light on a KZ650? What's next, power steering,power brakes, and a heater? :P Ed
  • pstrbrc
  • pstrbrc's Avatar
  • '81 GPz 1100 project
02 Nov 2008 19:46
#245271
This answer might be irreverent.
TAKE OUT THE BULB. LAY IT ON THE FLOOR. STEP ON IT.
There. That should take care of it.
:woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo:
\'81 GPz 1100 project
Elkhart, Kansas USA
\"Man does not control his own fate. The women in his life do that for him.\" Groucho Marx
  • trippivot
  • trippivot's Avatar
05 Nov 2008 07:25
#245684
empty the fuel tank and take out the sending unit. light sandpaper the string of coiled up wire and the slider contact.
or clean the corrosion off of the two contacts under the plate which hooked to a float.
either way you have some corrosion on a metal contact. could be either type of assembly.
  • drmadd95
  • drmadd95's Avatar
09 Nov 2008 13:59 - 09 Nov 2008 14:01
#246499
Love that fix: +1 :laugh:
1979 KZ650 B (Main Ride)
1978 KZ650 D1 (sold)
1982 KZ750 (parts bike)
Last edit: 09 Nov 2008 14:01 by drmadd95.
  • KaZooCruiser
12 Nov 2008 13:15
#247075
Well, golly. . .had the tank off anyway, due to throttle cable replacement necessity.
Pulled the sender, and there was all kinds of sediment which looked like it might have been the culprit.
It wasn't. (drat, double drat)
It's a solid state unit, with one wire going to something that looks like a bitty water tower, and the other wire going to a tall rectangle.
It's still available at the dealer for $90.00.
If that's the problem.
I guess tonight I look at a schematic.
Don't have to be at work tomorrow.
I got laid off today.
12 Nov 2008 14:04
#247081
KaZooCruiser wrote:
... still available at the dealer for $90....
Rumor has it that motorcycle fuel gauges are rarely accused of being accurate, even when new.
Good Luck! :)
