after market z650/z900/x1000 tacho wiring
16 Aug 2008 21:42 - 17 Aug 2008 14:17 #232416 by jimmybon
I've just received a new after market japanese electric tacho for my z650 hybrid, problem is that the instructions are in japanese.
It comes with RED, BLACK and long GREEN wire.
I'm assuming the RED is positive ( to the 1:4 coil YELLOW/RED wire ). The BLACK to the 1.4 coil BLACK wire, and the GREEN to earth,
I stand to be corrected
cheers
74 Z1A900 original
74 Z1A900 stone replica
74Z1A900 barn find
77 Z650B1 Hybrid
81 z650 PIG camp bike
06 ZRX1200R cafe racer project
S1000xr
Last edit: 17 Aug 2008 14:17 by jimmybon. Reason: missing the word electric
16 Aug 2008 21:46 #232417 by jimmybon
Replied by jimmybon on topic after market z650/z900/x1000 tacho wiring
whould anyone have an english copy of this?
74 Z1A900 original
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
18 Aug 2008 05:58 #232610 by jimmybon
perhaps that should be RED to power, BLACK to earth, and GREEN to coil 1:4
74 Z1A900 original
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
18 Aug 2008 07:51 #232633 by Sandy
Replied by Sandy on topic after market z650/z900/x1000 tacho wiring
Just curious...can you post a pic of that tach,for us to see.B)
1977 KZ1000 A-1
18 Aug 2008 12:46 #232708 by wiredgeorge
Replied by wiredgeorge on topic after market z650/z900/x1000 tacho wiring
The wire colors are meaningless. You likely ground the tach via a separate wire you stick in yourself on one of the connectors; such as a bulb connector. One wire will power the tach, one wire will power the tach light and the other to a coil. I suggest you fab a ground and run a wire from the red, black and green to a 12V source, like your battery and see what lights.
19 Aug 2008 00:01 #232839 by jimmybon
no wuz Sandy, here they are
74 Z1A900 original
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
19 Aug 2008 00:02 #232840 by jimmybon
and
74 Z1A900 original
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
  • Skyman
19 Aug 2008 08:38 #232884 by Skyman
Replied by Skyman on topic after market z650/z900/x1000 tacho wiring
Which wire activates the stop lamp? ;)
Seems like you'd need more than 3 wires to function properly. Unless it is as George suggested--that the tach needs to be grounded to the frame separately. Then you've got one wire to power the lights, one to power the brake indicator, and one going to the ignition. Does that sound right?
West Linn, OR
  • Skyman
19 Aug 2008 08:39 #232885 by Skyman
BTW, where did you find this tach?
West Linn, OR
19 Aug 2008 15:49 #232963 by jimmybon
I should have explained earlier that the lights all have there seperate wires (blue & black). It came with bulb plugs as with the original so i'v just pulled them out and used my existing bulb plugs.
I already have a brake light in the idiot panel so I removed the bulb plug and taped up the hole.
So that still leaves me a RED, BLACK and Lonnng GREEN wire to power the tacho from the coil:unsure:
74 Z1A900 original
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
19 Aug 2008 15:52 #232965 by jimmybon
ZPower Australia, $240AU
www.zpower.com.au
74 Z1A900 original
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
20 Aug 2008 15:33 #233156 by jimmybon
I'm going to try putting the BLACK & RED to a power source in the headlight and run the GREEN of the 1:4 coil
74 Z1A900 original
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
