Can 1/2 a coil go bad?
  • bountyhunter
  • bountyhunter's Avatar
Re: Can 1/2 a coil go bad?
19 Jul 2008 15:46
#227129
1978KZ wrote:
Here is the strange thing: I grounded the plug on the block and no fire, lifted it away (1/8") and they all would fire.
That's bizarre. It should not do that. have you tried replacing the plugs?
19 Jul 2008 16:01
#227131
30 year old plug wires may be deteriorated and leaking voltage. Z1E has a plug wire splicer to enable using same old coils with new Dyna plug wires. I prefer the Dyna solid wire core plug wires.
Should also assure having correct plug gap.
And as already suggested, would install four brand new plugs (NGKB8ES).
Good Luck! :)
