'79 KZ650 charging/electrical problems are driving me crazy
- jccwall
Re: '79 KZ650 charging/electrical problems are driving me crazy
11 Jul 2008 15:47
at idle 1200 rpm ac voltage ranges from 21.0 to 24.5 volts
at 4k it sits at 72.0 to 73.3. clymer calls for 75.0 ac.
this voltage is about the same on both stators i have. and both are 2 wires. i have another one here but it is a 3 wire.
jim
jim
- seanof30306
12 Jul 2008 03:14
Listen, don't be revving that thing up so much; it's old and needs to be babied!
Damn hot rodders
Damn hot rodders
"That @#$%!!! KZ650"
79 KZ650 B3
Dual front disc brakes
Z1R 18" front wheel
Pumper carbs w/pods
MAC 4-1 w/ drilled-out baffle
Dyna S ignition w/ Dyna Green coils
WG coil mod
'81 CSR charging system
17/41 gearing
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
- jccwall
12 Jul 2008 06:46
oh thats right 4000 rpm on a 78 bike.
kinda like sex for a 60 year old
should not be done....... oh but what a way to go
- wiredgeorge
12 Jul 2008 08:20
I would be surprised to see 75 VAC at 4K rpm... would think it would be ~40-50 VAC but if that is what they expect, that is what they expect. Main thing is that all possible tests are more or less the same.
- seanof30306
12 Jul 2008 14:25 - 12 Jul 2008 14:25
wiredgeorge wrote:
So, does that mean the stator's output is ok? If so, what test(s) do you suggest next?
What do you think about Jim's suspicions about the magnet?
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
Last edit: 12 Jul 2008 14:25 by seanof30306.
- jccwall
15 Jul 2008 11:13
wiredgeorge wrote:
Clymer calls for 75VAC, I got 72-73. Geaorge, do you think that rules the stator out?
If so, what do you suggest I look at next?
- jccwall
01 Aug 2008 17:51
ok all you kz wizards. this one is about to drive me to pulling hair.
have blown 2 regulators (i think) neither was new. one was 4 wire one was 5 wire.
test results,
yellow wires output 75 v ac after changing rotor.
black/yellow wire (which appears to be a ground) 140 mv
white/red wire shows battery voltage.
brown wire (for the 5 wire if im getting this correct) also shows battery voltage.
something here just doesnt seem right but im missing it.
please what am i missing/overlooking?
dont want to put another regulator in unless everything is where it is supposed to be.
also are these regulators like on a car, must disconnect battery before connections are made?
thanks for any assist.
jim (the rattled one)
test results,
- Saki Jockey
01 Aug 2008 18:12
You may have a parasitic draw, if so it needs to be fixed first as indicated by WG.
I agree.
If your parasitic draw is significant enough, it may overcome the charging system on your bike.
Leave the bike overnight without the charger in place. Measure battery voltage at the terminals. Remove the negative cable wait 10 minutes and remeasure with the negative cable removed, report results here.
Have your battery load tested, or crank the starter and measure what voltage the battery drops to. Report info here.
When servicing your vehicle, it is best to remove the negative cable to prevent accidental shock. It serves no other purpose.
I agree.
Rob A.
550 A4
GTA,
Ontario, Canada
550 A4
GTA,
Ontario, Canada
- jccwall
09 Aug 2008 12:34
update,
using both meter inline for draw test and a light bulb, same config, no power unless turning on the key. turn off and light goes out.
battery status, on charger for 3 days so full charge, off now for 2 days, 12.9 volts and drops to 10.6 while cranking with headlamp on.
- MFolks
09 Aug 2008 14:21
Have you considered the ignition switch may be shorted internally. Do you have the wiring diagram so we can puzzle this out with you? I still think a pinched/burned wire is to blame.
- jccwall
11 Aug 2008 05:50
good possibility and yes i have wiring diagram.
thanks
jim
thanks
jim
- MFolks
11 Aug 2008 09:37
Motorcycle switches can fail internally for several reasons: 1. Having a mass of keys on a key ring in the ignition switch causing wear internally. 2. Vibration from the normal operation of the engine(things buzz and shake at different frequencies,mirrors blur,pegs hum and shake etc).
