Another wonderfully vague electrical question, answers should be similar.
- Sweet Back
Re: Another wonderfully vague electrical question, answers should be similar.
12 Jul 2008 10:43
and I tied off the clutch kill switch.
- Stargate
12 Jul 2008 12:37
I know our bikes aren't the same but wiring should be very similar. Keep in mind colors may be different. Power from ign switch comes in to the kill switch on a red/yellow and exits on red going to the start button. If you have no power to the start button check for voltage on the input to the kill switch.
1981 KZ1000-K1 LTD
Original owner
Photos
Original owner
Photos
- Sweet Back
16 Jul 2008 09:32
I'm defintitely at a loss here. If I've got 12 volts on one side of the solenoid, why don't I have it on the other. I've tried 2 different solenoids. Anybody have any suggestions?
- SPARKY47
- 1980 KZ500 B2
16 Jul 2008 11:22 - 16 Jul 2008 11:23
Sweet Back,put a circuit diagram up. I don't know your model, but electrical tech is easier with a drawing
1980 KZ500 B2
Last edit: 16 Jul 2008 11:23 by SPARKY47.
- Sweet Back
17 Jul 2008 16:16
This is the electrical if thats what you mean. You can down load it here. 19mb file.
www.filefreak.com/pfiles/56769/electrical.bmp
- SPARKY47
- 1980 KZ500 B2
17 Jul 2008 17:20 - 17 Jul 2008 17:59
I d/l your diagram, I'll post asp.
where on the bike is the "starter lockout switch"?
anybody?
anybody?
1980 KZ500 B2
Last edit: 17 Jul 2008 17:59 by SPARKY47.
- SPARKY47
- 1980 KZ500 B2
17 Jul 2008 18:04
disconnect all positives from battery.
unplug connector feeding solenoid,this should have a black,
and a black/yellow
set meter to lowest resistance setting.
connect one meter lead to battery negative.
connect other meter lead to black/yellow on harness side of
disconnected connector.
your meter should show short circuit[same as connecting
meter leads together].
this confirms integrity of earth[battery negative] to solenoid.
All good?
if yes then continue.
reconnect all positives to battery.
do not reconnect solenoid connector at this stage.
you should have a connector which goes to your :
lighting switch and
pursuit switch and
stop switch and
starter switch[starter button] and
siren switch.
this connector has 8 wires
blue L
red/blue R/L
blue/yellow L/Y
red/white R/W
green white G/W
yellow/red Y/R
red R
black B
pull this connector apart
set meter to whatever scale to enable you to read 12 volts dc
turn ignition key to position 1
connect meter negative lead to battery negative
connect meter positive lead to yellow/red on harness side of
you should read 12 volts
if yes then turn ignition off.
disconnect meter from yellow/red
disconnect meter from battery negative
disconnect all battery positives
set meter to lowest resistance scale
connect one meter lead to black wire on harness side of 8
wire connector.
connect other meter lead to black wire on harness side of
solenoid connector
Tell me your results.
and a black/yellow
All good?
lighting switch and
pursuit switch and
stop switch and
siren switch.
blue L
red/blue R/L
blue/yellow L/Y
red/white R/W
green white G/W
yellow/red Y/R
red R
black B
wire connector.
solenoid connector
1980 KZ500 B2
- Sweet Back
24 Jul 2008 00:36
Everything came out exactly as you stated in your post. Nothing different. And thank you for your time on this.
- SPARKY47
- 1980 KZ500 B2
24 Jul 2008 01:14
I can continue with this tonight if you wish?
1980 KZ500 B2
- Sweet Back
24 Jul 2008 20:23
I think I'm just gonna take it in. I appreciate all of your help.
- RetroRiceRocketRider
24 Jul 2008 22:17 - 24 Jul 2008 22:18
Everyones tips (all good ones btw) are having you test the same components over and over, just in different orders.
Try this test and see if it helps:
Turn the ignition switch on, put the kill switch to the ON position, and while holding the starter button in, slowly turn the ignition switch key slightly in either direction and see if your beast wakes up.
If so, then the ignition switch contacts are worn and/or corroded.
I've been dealing with this same sceanrio on my ZN700 for the past few years, which makes riding really exciting when it cuts out while negotiating through a see of inattentive cagers at 75+ mph. :S
A slight (approx 1/8" ) turn of the key to the left and ignition power is restored, which is confirmed by a throttle that responds again and a HUGE f-ng backfire! :woohoo: :blink: :laugh:
Cleaning and adjusting (bending) the contacts helps for a while, but the prob eventually returns.
One of these days I hope to get lucky and find a NOS ignition switch (it's no longer available through Kawi) on eBay and put this prob to rest for good.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
Last edit: 24 Jul 2008 22:18 by RetroRiceRocketRider.
- SPARKY47
- 1980 KZ500 B2
25 Jul 2008 01:06 - 25 Jul 2008 01:24
mods please delete
1980 KZ500 B2
Last edit: 25 Jul 2008 01:24 by SPARKY47.
