- Thank you received: 1616
diagram for BigBlockT
- loudhvx
ignore the colors for the lighting wires. They may not match your bike.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- Stargate
1981 KZ1000-K1 LTD
Original owner
Photos
- steell
Shouldn't there be an igniter in there somewhere?:blink:
Not familiar with the Dyna S are you?
No, there is not supposed to be an igniter in there, the Dyna S is an all-in-one unit.
- BigBlockT
- wiredgeorge
- loudhvx
1981 KZ550 D1 gpz.
Other links.
- loudhvx
The actual color of the wire is written in 3-letter code, but are obviously subject to change as necessary.
14 gauge wire is not very fun to work with. I usually use 16 and 18 for everything outside of the starter wiring. The stator wires may only be 18, but I'm not sure. Use 16 to be safe.
Obviously, you can use thicker wire. If you don't want to buy a bunch of sizes, stick to 16 for everything that's black and blue. 16 is probably the size I use the most of.
1981 KZ550 D1 gpz.
Other links.
- loudhvx
1981 KZ550 D1 gpz.
Other links.
- loudhvx
1981 KZ550 D1 gpz.
Other links.
- BigBlockT
- BigBlockT
- loudhvx
1981 KZ550 D1 gpz.
Other links.
