Looks like I may have an alternator problem...
- kzmason
Re: Looks like I may have an alternator problem...
05 Mar 2006 16:10
Well that did it. Does that mean my rectifier is toast?
- loudhvx
05 Mar 2006 16:20
kzmason wrote:
That's what it's looking like. So it doesn't draw any current when you pull the rectifier wire, or the blue stator wire, or both?
Then I guess it's time to look for a rectifier. You can probably get one on ebay or you could try to get a modern, one-piece rectifier/regulator. You could also try to make a rectifier for about $10 or $15:
www.geocities.com/loudgpz/GPZdiy3phaseRectifier.html
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- kzmason
05 Mar 2006 18:35
Would I need to do any adapting to install a combo unit?
- loudhvx
05 Mar 2006 22:24
A combo unit would have to connect to the three wires from the alternator (pink, blue, yellow), the output to the battery (white), ground (black), and the switched positive wire to sense the battery voltage (brown). These wires are contained on two different connectors. If you are going to use a combo unit from another model then you will probably have to do a little re-wiring, not much though. If you use a combo unit made specifically for your bike, I would assume it just has two connectors on it, but I really don't know.
You may want to start a new topic asking specifically what you are looking for. Someone else probably already went through this and they could probably give you better deails.
1981 KZ550 D1 gpz.
Other links.
Other links.
- savedrider
- 1975 Z1-B 900
06 Mar 2006 09:19
I highly recommend upgrading to the combo unit for your bike if you can afford it. They are plug and play and work nicely. Z1 Enterprises has them for a good price.
Get right or get left! <*{{{><
