Kick start works better than electric start on my '76 KZ750
  • genesis
  • genesis's Avatar
Re: Kick start works better than electric start on my '76 KZ750
09 May 2008 08:39
#212305
PFC FNG wrote:
How do you kickstart a bike?
put the bike in neutral. flip out the kick starter, do not pull in the clutch and start kicking. Your bike will take a few kicks when it's cold (shouldn't be more than 3-4 on a bad day)as long as there's gas in the tank and the battery is charged.
  • 28years
  • 28years's Avatar
  • Live to ride
04 Jul 2008 13:38
#224028
Hello:
My 1979 kz750 b1 bike has to be kick started too. Lately, I bought a service manual on E-Bay and found it quite informative.
I have power to the seloind, which then transmits power to the starter. The starter turns and drives the chain, but it doesn't turn the motor over--just like what is reported here by others.
The idea of removing the starter clutch is something that I would like to pursue. There is one thing though, you need a special tool, a "dynamo rotor puller" and "spanner wrenches."
It seems that some guys are successful in getting their starter clutch working by replacing springs on their model motorcycles.
Since there are so many models of motor cycles, I hope that someone here can focus their description on their work on this model of bike--KZ 750 B1.
Doug Johnson
KZ 650 B2 1978/KZ 1979 B4
  • steell
  • steell's Avatar
05 Jul 2008 00:05 - 05 Jul 2008 00:06
#224174
Special tool to remove the rotor? Try using the rear axle, it works just fine :)
Sounds like your starter clutch is bad, it's a common problem.
Take out the bolt that holds the rotor on, screw in the axle as tight as you can, smack the end of the axle with a big ol hammer, and the rotor should pop right off. The rotor is a taper fit, as soon as you break the taper it's loose.
By the way, a 79 KZ750 is a B4, not a B1, the B1 is a 76.
Last edit: 05 Jul 2008 00:06 by steell.
  • HTBeedz
  • HTBeedz's Avatar
13 May 2026 17:06
#923902
So uh. What’s wiredgeorge’s coil mod? Can anyone help with this, because the link is dead. TIA
  • sf4t7
  • sf4t7's Avatar
  • Away
13 May 2026 19:05
#923906
Search "ignition by-pass relay-W "
The posts also have a wiring diagram
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
16 May 2026 18:43 - 16 May 2026 18:43
#924004
HTBeedz post=923902 userid=83234... What’s wiredgeorge’s coil mod? Can anyone help with this, because the link is dead. TIA
wgcarbs.com/index.php/14-sample-data-articles/89-coils
If you choose to pursue this mod, we suggest you use a modern blade fuse instead of an old-style glass tube fuse for the 10A fuse shown in the diagram.  Don't cheap out on the relay.
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
Last edit: 16 May 2026 18:43 by slmjim+Z1BEBE.
