Source for wire?
  • Beatpoet
  • Beatpoet's Avatar
Re: Source for wire?
27 Apr 2008 06:16
#209420
Beatpoet wrote:
They have wire in Radio Shack..
'Automototive hookup wire' (12ga.) and other spools of smaller sizes.
Wow, I've never been so completely ignored.
  • PLUMMEN
  • PLUMMEN's Avatar
27 Apr 2008 09:47
#209484
ive used the radio shack wire before,wasnt really happy with the insulation they use on there wire.
  • loudhvx
  • loudhvx's Avatar
27 Apr 2008 09:52 - 27 Apr 2008 09:57
#209487
They don't have all the KZ colors with the right colored stripes as he was asking about.
Last edit: 27 Apr 2008 09:57 by loudhvx.
  • loudhvx
  • loudhvx's Avatar
27 Apr 2008 09:54 - 27 Apr 2008 09:56
#209488
Patton wrote:
If interested, Z1E carries wiring harness sets for Z1 models. :)
Z1 Wiring Harness
This has to be the cheapest way to get the right colors, unless you plan on making many harnesses, then the bulk route may be cheaper. At least, I assume the colors would be same as a stock harness.
Last edit: 27 Apr 2008 09:56 by loudhvx.
  • Beatpoet
  • Beatpoet's Avatar
27 Apr 2008 11:28
#209508
Ahh... Original colors.
I have been tempted to replace a couple of decaying connectors while using the original wires with these:
www.radioshack.com/product/index.jsp?productId=2103252&cp
  • loudhvx
  • loudhvx's Avatar
27 Apr 2008 11:49
#209521
I'm using some of those connectors. They work well if you have the right crimper. I don't, so I usually solder the connector onto the end of the wire. That's not really the proper method, though, and can lead to premature breakage of the wire if it's not done correctly. I just barely solder the tip of the wire to the connector to retain some flexibility in the wire. If it's over-soldered, the wire can break inside the insulation. The proper crimper would be superior.
