Ugh- Ignition PROBLEM
- Qdude
- It is all good.
Re: Ugh- Ignition PROBLEM
17 Apr 2008 22:15
I know that you are good at engines. I am way curious what it is.... Was there spark?
Is there an intermittent power issue? Maybe there is a wire that cuts, shorts or overheats?
Ahhhhh!
Ahhhhh!
77 KZ 650 C1.
77 KZ 650 C1.
77 KZ 650 C1.
- cuds
18 Apr 2008 13:26
I haven't sat down and played with it yet. I'm going away for the weekend, I'll get to it sometime early next week I'm hoping.
Erik B
Bay Area, CA
1976 KZ900
Bay Area, CA
1976 KZ900
- Beatpoet
18 Apr 2008 14:01
I had the same problem on my four-banger. The cylinder in question was running way too rich due to a leaky diaphragm in the vacuum petcock.
... Rich meant it would only fire at high rpm, and the gas mileage was poor.
Keep an eye on the plugs.
Sandy wrote:
Erik...what's the scoup on your CARBS bud?
Maybe it ISN'T ignition,because yes,you're right...2 and 3 ARE fireing off the same coil.(they better be wired up that way,anyway)
Have you had the carbs apart?
How long has the bike sat with fuel in the bowls?
- Becker
- The Doctor Will Rise Again
19 Apr 2008 10:21
Someone on here said that the coils have to fire both spark plugs at the same time or else the won't fire at all. Is that true??
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
- loudhvx
19 Apr 2008 11:17
Becker wrote:
Yes, basically that is true. In order for spark to occur at one of the pair, there should be spark at the other one of the pair. The only exception is if the spark is leaking to the frame or engine through the wire or through the coil or inside the coil.Someone on here said that the coils have to fire both spark plugs at the same time or else the won't fire at all. Is that true??
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- Beatpoet
20 Apr 2008 00:40
Test the resistance between each plug cap and the engine case.
- cuds
23 Apr 2008 21:15
UPDATE:
I went over all connections and checked them for proper clips and made sure then were clean and together correctly. I then replaced the battery like was suggest to...started right up using the electric starter. Runs well! So, cylinder 1, 3 & 4 are running perfect! Cylinder 2 still won't fire. I pulled the plug out and tested it, it had a fat blue spark. Which tells me it's getting spark. Soooo, it leads me to a carb problem? Not getting fuel or something? Not quite sure, I'm going to tear into it when I get time. I'm just digging away at this project one piece at a time.
Also, cylinder 1's CARB keeps bacfiring out of the air filter. Like a "puff" backfire, not so much of a flame 'boom'. I don't know, it's hard to explain. LOL
Thanks,
-Erik
Thanks,
-Erik
Erik B
Bay Area, CA
1976 KZ900
Bay Area, CA
1976 KZ900
23 Apr 2008 21:27
If not already done, would do compression
test (at least on on cyl#2) and especially
check valve clearances on #2.
As known, acceptable cold compression psi
may be lost at normal operating temp.
This can happen when a too tight valve
is barely closing enough when cold but
fails to completely close when warm.
Good Luck!
Good Luck!
