Nuetral switch starting issues?
  • wiredgeorge
  • wiredgeorge's Avatar
Re: Nuetral switch starting issues?
07 Feb 2008 11:13
#193281
Go look at a wiring diagram before progressing to far as far as the color codes... The yellow/red is USUALLY the coil power. I know they pull coil power from this area on some of the KZ550s. The BLACK is usually the trigger for the solenoid and that is the wire coming from the start button. The solenoid sometimes has a ground wire and sometimes doesn't, depending on the model. The ground is supplied by the bolts in the starter where they meet the engine cases. If there is a ground wire, it should likely be connected to the reg/rec and may be BLACK... The ONLY power that should come out of a solenoid should be on the big lug where the starter wire connects but my memory tells me that a 550 may have power coming from this area for the coils. Perhaps loudvhx will chime in as I don't have diagrams for this bike only a poor, old and very faulty memory. I worked on a KZ550 race bike last year and I dimly remember power coming from the solenoid area and not the normal path out of the right switchgear to a connector above the coils.
  • 76 LTD
  • 76 LTD's Avatar
07 Feb 2008 16:09
#193338
My 79 LTD was pulling the same crap it turned out to be the wires going to the clutch safety switch.
  • ThatGPzGuy
  • ThatGPzGuy's Avatar Topic Author
07 Feb 2008 18:46
#193368
Success!
I think it was a bad connection. I took a couple connectors apart to clean and check some things and when I put it back together to check the starter switch it worked. Even the nuetral light works which leads me to believe it was one of the pin connectors.
Thanks everyone,
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • ThatGPzGuy
07 Feb 2008 18:49
#193370
Success!
Thanks everyone,
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
