confused as heck
- oldkaws4ever
- Have no regrets...... You only live once.
Re: confused as heck
04 Feb 2008 20:30
ya ur right cptEDIV
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- NickW900LTD
- Nick
04 Feb 2008 20:45
ok thanks!!! I originally had it 1,2,4,3 and it didnt run right at all?
1976 KZ900 LTD (sold)
1977 KZ1000 LTD
1978 KZ1000 A2A
Pierceton, Indiana USA
1977 KZ1000 LTD
1978 KZ1000 A2A
- oldkaws4ever
04 Feb 2008 20:51
no prob, just remember to match up the numbers on the plug wires to the right cylenders and that old kaw will purrr like a kitten.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
06 Feb 2008 04:43
loudhvx wrote:
The FSM for '73Z1-'76KZ900 contains four diagrams. The 1st diagram is Z1 US model with green wire from right-side points to right-side coil feeding inner plugs 2/3 and black wire from left-side points to left-side coil feeding outside plugs 1/4 (correct). The 2nd FSM diagram for Z1 European model is the same.
The FSM then errs in the 3rd diagram (shown above) for KZ900 (US and Canada model) which erroneously has the wire colors reversed from the points to the coils. The same color combination is shown for the KZ900 European model in the FSM's 4th and final diagram (which is likely also incorrect).
The FSM Supplement for '76KZ900LTD also erroneously reverses the wire colors from the points to the coils on both the USA and Canada model diagrams.
This is consistent with the info as posted by wg.
P.S. The FSM for '77-79 KZ1000 also looks wrong, at least for '77 and '78 (before pickups and igniter) and I'm guessing the FSM's '79 diagram for European models showing green wire from igniter to left-side coil and black wire to right-side coil might also be wrong.
Post edited by: Patton, at: 2008/02/06 07:50
Post edited by: Patton, at: 2008/02/06 07:53
Post edited by: Patton, at: 2008/02/06 07:59
Post edited by: Patton, at: 2008/02/06 08:12
Post edited by: Patton, at: 2008/02/06 08:16
...was surprised to see this factory diagram for the 76 900 A4:
kzrider.com/component/option,com_docman/...ew/gid,92/Itemid,49/
Diagrams have been known to be wrong, but this is sort of a BIG error...Here's what I see on the diagram:
. <br><br>Post edited by: loudhvx, at: 2008/02/04 14:22
- loudhvx
06 Feb 2008 23:47
They may have switched sides for the coils at some point, or at least on the the other model lines. The 550's have:
1,4 black-wire coil on the right side (fired by left pickup).
2,3 green-wire coil on the left side (fired by right pickup).
This is based on looking at actual bikes (about a dozen or so. (I have one 81 model which wasn't touched since 1986.)
But the manual for the 550 shows several diagrams with the coils swapped left and right, but black always feeds the 1,4 coil and green always feeds the 2,3 coil. Also the pickup on one diagram is shown with the blue/black pickup on the right and the yellow/red pickup on the left, but this is absolutely wrong.
I guess my point, then, is that I don't think we can imply the physical layout from the wiring diagrams. But, we should be able to imply spark plug numbers when they are written in, and wire colors. (In that case, the 76 900 A4 diagram I showed is wrong either way.)
If only Kaw would have stuck to one convention and then drew it the same each time...
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- loudhvx
07 Feb 2008 00:36
So I corrected my copy to this.
I don't know if it's worth it to upload it to the filebase. If I convert it to PDF, it doesn't look as good as this Jpeg.
This is just a blow up of the coil portion.
1981 KZ550 D1 gpz.
Other links.
Other links.
