charging?
- quader98
Re: charging?
17 Dec 2007 15:03
ok,key off same as batt 12.55
key on not running .705
running .845 charging st 14.72 @ 4000 rpm's
oh and i finnaly found the pink wire for the batt level,batt warning light is now off
Post edited by: quader98, at: 2007/12/17 18:04
Ernie from central jersey
82 GPZ 750 R1
looking to part out my 81 KZ750E2
82 GPZ 750 R1
- loudhvx
Re: charging?
18 Dec 2007 09:34
14.7 is a little on the high side. 14 to 14.5 would be better. Just keep an eye on it in case it starts to climb. Also check your battery's water level every 3 or 4 hours of running to make sure it's not boiling off.
If the voltage goes higher than 14.7 you'll have to find out where the brown line is losing voltage and clean or replace the connection/contact or wire.
Some people find a way to strap the voltmeter on the tank for temporary troubleshooting. Then go on a ride and watch what the voltage does. It's dangerous, though (for obvious reasons), only ride on non-busy roads that way.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- quader98
Re: charging?
18 Dec 2007 12:47
ok,thank you very much loud i appreciate all the help you've given me
82 GPZ 750 R1
82 GPZ 750 R1
- 1982KZ1100D1
Re: charging?
19 Dec 2007 17:01
After being stranded one time due to charging problems, I don't ride without a volt meter of some type to keep a eye on what is going on. I like the Kuryakyn
lifeisaroad.com/stories/2004/10/27/kuryakynLedVoltmeter.html
and will install one on my 1100 when it's running.
Post edited by: 1982KZ1100D1, at: 2007/12/19 20:09
- quader98
Re: charging?
19 Dec 2007 18:03
yea thats not a bad investment...thanks
82 GPZ 750 R1
82 GPZ 750 R1
