We seem to be having a problem getting the engine past 4000 rpm. It has 2 exhaust pipes with no crossover pipe. Could that be a problem? 1&2 into one pipe, 3&4 into the other. The compression is about 125 lbs in all cylinders. Could the old coils be breaking down at high rpm? Mabey the new Dyna coils will solve it. Power to the coils is just under 12 volts. Thanks again.
