- Thank you received: 1616
:S OK where do I begin..I have read and copied the diagragms to re-wire my "77" KZ1000...I have already pulled all the wires..it was a mess...I have the aftermaket R/R and also a new starter soleniod.(both from Z1 Enterprizes and made by Ricks Stators)...I am also using new ATC blade fuses and fuse block..what came on the bike is Accel coils and a Dyna S...I want to be sure that I can eliminate the 4 wire blocks/connectors...I have the 86 relay so I can wire the coils as per Wired Georges instructions...I also have put in a new H4 headlight and using Clear Alternatives Hayabusa smoked tail lens and LED light...where I'm pulling my hair out is wiring in the new soleniod coil wires...they are not matching colors to anything..I see in the bare bones diagragm that the Blk/Yellow from the Sol.coil ties into the Green/Ground..does this need to tie in or can I just Ground it to the frame??..I am not running anything on the bike.."bare bones"..no neutral,oil light..no gauges..just a headlight..no highbeam/lowbeam..highbeam only..brake light/tail light only..it looks like the "bare bones" diagragm will work just fine for me..any ideas or mods please let me know...PS..I'm also putting on some green LED pods but these will be wired to a hidden toggle and switched on only when the bike is parked...Thanks for any and all help...I can't wait to get this old beauty back on the road...crunch time...Bike Week is starting and I live 60 miles south of Daytona..Tracy
