Yes, but get a new one, or a very recent used one. 35 year old reg/recs might not have much life left in them. They can fail in a gradual way, which means it can strand you miles from home with no battery to get you back.rift.sawn wrote: Thanks again. As I look for parts to piece this diagram together, I see regulator rectifiers for the '80 KZ750G twin that have only four wires: two from the dynamo/stator, a black to ground, and a red/yellow. The brown seems to be missing. Since we'd be splicing the brown into the red/yellow in the diagram, is it safe to go with one of these 4-wire regulator/rectifiers?
loudhvx wrote: I use point-to-point wiring rather than the sectioned harness from the factory. So basically the whole bike is one big harness, with a couple subharnesses, like for the pickup plate, and handlebar area.
I use generic, 1/4" crimp spade terminals. This greatly reduces the supplies I need to carry when I go to rewire a bike. Large connectors are needed if you have a more complex wiring. I usually do bare-bones stuff so it's pretty easy to just memorize it.
Crimped connectors seem to last longer, in my experience. Soldering weakens the copper and sometimes promotes corrosion. I will solder a T joint in the harness as long as I know it's going to be supported by other continuous wires, and will be taped over to keep out moisture.
So with all that, I just use automotive wire available at auto parts stores. Pep-Boys had a pretty good selection of sizes and colors.
Basically, I keep things simple and make sure my supplies are easily available, since I will often end up rewiring a bike on the fly. It's often faster than trying to troubleshoot a hundred other wiring problems. And usually, when I pull and old harness, and dissect it, I find many places where the harness has failed is is about to fail.
