- Thank you received: 1616
loudhvx wrote: 1983 KZ750 K1, KZ750K1, twin.
I don't have a U.S. K1 diagram, so this one is based on a West German diagram.
Is this for the B or the G? If you are not using electric start (obviously the Spree battery won't turn over a 750), then you can use any simple key switch. But, of course, you can still use the 3-position car switch if you want.xbmxxx wrote: I should have mentioned, I do plan on running a small battery out of a honda spree or something of the sort. I am in the habit of always starting my bike in neutral, so the clutch shouldnt be a problem. So just whatever it takes it to run, headlight, tail, brake, auto style key ignition. Sorry for being such an annoyance! I have no factory wiring to compare to so I am doing it all from scratch.
