1980 750H bare bones for mattylight
  • loudhvx
  • Topic Author
14 Jun 2011 15:13 #457262 by loudhvx
Replied by loudhvx on topic 1980 750H bare bones for mattylight
Yeah, no problem. Do you know what starter and ignition switch you will use? Will you keep the kill switch? Sticking with points?
The following user(s) said Thank You: sk8vet
15 Jun 2011 14:38 #457422 by sk8vet
Replied by sk8vet on topic 1980 750H bare bones for mattylight
Hey, sorry for the false alarm but I'm going to stick with the stock wiring until I get it running right. Afterwards I'll do something more custom and probably come back here ;-). Thanks for the reply tho!
  • loudhvx
  • Topic Author
18 Jun 2011 11:21 - 10 Jan 2019 10:30 #457994 by loudhvx
1979 kz650 for grabber.
Drag to the desktep to see in full resolution.
This is for the U.S. models. I don' know if the U.K. models will have variation.
Ignore the stuff to the right of the arrows. That's just for lighting in case you need it in the future. But it would require an ignition switch so the lights won't be on all the time.
EDIT 1/10/2019:
Mattylight Barebones Bare Bones
1979 Kawasaki Kz650 for grabber
Kz 650
Last edit: 10 Jan 2019 10:30 by loudhvx.
18 Jun 2011 11:30 #457997 by grabber
Replied by grabber on topic 1980 750H bare bones for mattylight
That's great thanks
  • loudhvx
  • Topic Author
19 Jun 2011 11:10 - 10 Jan 2019 10:31 #458163 by loudhvx
added starter
EDIT 1/10/2019:
Kz 650
Last edit: 10 Jan 2019 10:31 by loudhvx.
26 Jun 2011 00:54 - 26 Jun 2011 00:56 #459384 by sk8vet
Hi loudhvx,
I'm back and hoping you can help me out now that I have my plan straight. Again, I have a 78 KZ650 C2 with the following wiring diagram:
diagrams.kz650.info/wiring/images/KZ650-B2,C2.jpg
BUT, my bike didn't come with right hand controls so I found one from a C3:
diagrams.kz650.info/wiring/images/KZ650-B3,C3.jpg
You'll notice the C3 right controls has a mystery yellow wire going to the ignition, and no headlight on/off switch which has me a bit confused.
Will you please help me with a wiring diagram based on the C2, with the C3 right controls, and with the following "deletes":
-No hazards
-No horn
-No speedo or tach
-No front indicators (turn signal indicators, neutral, high beam, oil, brake light fail)
-No starter lockout switch
Since I have no headlight on/off switch I'd like them to be on when I turn on the ignition key (ignition is off/on/park). Also, I will be using points for the time being.
What do you think? Doable? :unsure:
Last edit: 26 Jun 2011 00:56 by sk8vet.
  • loudhvx
  • Topic Author
26 Jun 2011 11:13 - 10 Jan 2019 10:33 #459434 by loudhvx
I tripled up on the ignition switch contacts to make the ignition switch more reliable. As it's drawn, the input and output of the ignition switch will have 3 wires tied together. Input will be red and two whites. Output is brown, blue, and orange/green. THe blue may actually be blue with a red stripe, or red with a blue stripe.
EDIT 1/10/2019:
1978 Kawasaki Kz650C2 for Sk8vet
Kz650C Kz650 C2 Kz 650 C 650C2 650C
Last edit: 10 Jan 2019 10:33 by loudhvx. Reason: Corrected title on image
26 Jun 2011 11:31 #459440 by Patton
Replied by Patton on topic 1980 750H bare bones for mattylight
If needed, here's how to save a forum image to your computer:
Click > www.kzrider.com/forum/8-about-the-site/4...age-to-your-computer
Good Fortune!:)
The following user(s) said Thank You: loudhvx, nkymain485
  • loudhvx
  • Topic Author
26 Jun 2011 11:49 #459443 by loudhvx
I put a link to it in my signature.
Thanks Patton.
The following user(s) said Thank You: nkymain485
26 Jun 2011 13:39 #459454 by sk8vet
amazing! thank you SO much for your help! next time you're in LA, i owe you beers B)
  • loudhvx
  • Topic Author
26 Jun 2011 15:04 #459470 by loudhvx
No problem. Hope it works out. :)
  • loudhvx
  • Topic Author
16 Jul 2011 14:15 - 10 Jan 2019 10:36 #463164 by loudhvx
Bare bones 1979 KZ 750 B4 KZ750 B4 750B4 KZ750B4 twin for Frank Parks
EDIT 1/10/2019:
1979 Kawasaki Kz750B4 twin for Frank Parks
Kz750B Kz750 B4 Kz 750 B 750B4 750B
Last edit: 10 Jan 2019 10:36 by loudhvx.
