Open up a speedo/ Tach?????
  • cgray34
  • cgray34's Avatar Topic Author
28 Aug 2007 12:55
#166910
Anybody know how to open up a speedo or a tach to repair or rebuild the inner components, window, etc??????
  • patmann
  • patmann's Avatar
Re: Open up a speedo/ Tach?????
28 Aug 2007 13:37
#166921
There used to be a posting on it in the old forum about this very subject !! Bob @ Z1 Resto does fix them.
1974 900 Z1 modified to look like a LTD , some engine mods. But I still have all the original parts.
1977 1000 project bike
1972 H1 project bike
If pro is opposite of con, then what is the opposite of progress?
  • cgray34
28 Aug 2007 13:48
#166924
thanks, I will search the archive again.
  • 77Davo650
  • 77Davo650's Avatar
28 Aug 2007 13:51
#166925
I remember an old posting also, something about you have to pry the aluminum/steel (I don't know) ring off that holds the face cover to the body. It's not that bad it said, but getting it back on and flattening out all of those pry marks seems like it would be a pain.
77 KZ650 C1 (sold)
78 KZ650 B2 (sold)
78 KZ400 B1 (sold)
78 kz400 C1 (resto-mod)
78 kz400 C1 (hardtail low chop)
couple of possible project kz's in parts
  • cgray34
28 Aug 2007 13:58
#166928
after a little more extensive searching I found the archive.
www.kzrider.com/archive/viewthread.php?f...772&action=printable
Thanks for pointing me in the right direction.
  • duncan
  • duncan's Avatar
28 Aug 2007 14:13
#166933
it's very easy to cut a gauge open with a dremel and close it with a bit of glue and a 3" hose clamp, like suggested here:
www.cb750cafe.com/parts.php?id=5&PHPSESS...b2b8523e8089011a564b
the trickiest part is taking off the (press-fit) needle, but it finally came off.
Post edited by: duncan, at: 2007/08/28 17:17
  • Wilde
  • Wilde's Avatar
29 Aug 2007 00:37
#167054
It is a pain to get the ring off and on in one piece, I have heard that new rings are available somewhere but have not been able to locate them. My tach ended up beeing silvertaped...
  • Wilde
  • Wilde's Avatar
29 Aug 2007 00:37
#167055
  • JMKZHI
  • JMKZHI's Avatar
Re: .
29 Aug 2007 04:54 - 03 Dec 2008 09:48
#167074
del
Last edit: 03 Dec 2008 09:48 by JMKZHI.
  • Bluemeanie
  • Bluemeanie's Avatar
29 Aug 2007 08:18
#167105
Pryed mine off years ago and crimped back on, I could have done better job but doesn't look too bad.
  • AK 81 CSR
  • AK 81 CSR's Avatar
29 Aug 2007 10:30
#167137
I've restored two differnt sets of guages for my bike and I found the best way to get the rings off is the way duncan suggested, i.e., cutting with a dremel tool. The crimping/uncrimping method works but it almost impossible to do it in such a way that the ring will not show the marks on the bottom side. The trick to getting the needles off is the two spoon pry method. In addition, I'd be very carefull not to wipe the face plate with anything as the ink from the letters/numbers can smear. Use a soft brush or compressed air. Wiredgeorges how to on this is a very helpfull. And if you run into a problem you can contact Z1 Resto and talk with Bob Harrington, he's a great guy and very helpful.
  • wiredgeorge
  • wiredgeorge's Avatar
29 Aug 2007 11:28
#167145
The original question was whether it is possible to get into the gauges and effect repairs. While it is very possible to get into the gauges as my old how-to post shows, I doubt you will get much repaired. If anyone has TRIED to repair anything inside a gauge they will understand this comment... I have only broken stuff bwhahaha Big Nose Bob Harrington is the only one I know who can REPAIR and RESTORE vintage Kaw gauges... You can find his website through z1enterprises.com site I think.
