You guys have all that money to buy a new set of coils.The jet cars are sept. 14th I think.
. . .had a smoke, while the bike sat for about 10 minutes. Fire it back up and all is good.
Once it fired up after letting it sit,there were no issues with it the rest of the way home(over an hour later). . .this weekend,it started doing it again . . .let it sit for a while,and then fired it up and all was good.
So this morning I go out and fire it up...and it runs perfectly.
So I'm wondering if the coil was getting too hot(from the engine and outside temp),and if there's a way to test the coil for heat-failure,with the symptoms given.It does seem to be getting worse though,compared to the first time it happened.
These coils are new Dyna coils last year...ish(2.2 ohm)and I'm getting readings of 2.9-3.1 ohms.
Again...riding the bike,after a while,it will cut out on 1 and 4...let it sit for about 10 minutes and it fires right up and runs fine...for a while then cuts out again.
When it happened the first time(about 3 weeks ago),We had clocked about the same amount of miles as We did the second time it happened(yesterday)...about 3 hours of riding.
Any ideas?
