KZ 650 B batt overflowing
- loudhvx
Re: KZ 650 B batt overflowing
29 May 2007 23:32
skydailey wrote:
Depends on what year you have. EDIT: I see from the other thread, you have a 1977. That bike needs a battery. Do a voltage check on the brown wire at the regulator.
Also, make sure the wires are on the correct connections. The reg has color marks on it at the connections corresponding to the wire colors.
Post edited by: loudhvx, at: 2007/05/30 02:46
thinking of taking the batt. out all together! Ive heard of the bat-pac; a capacitor that replaces battery but cannot use the elect starter anymore. what do you guys think??
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- skydailey
30 May 2007 05:33
Ok, lets get elementary for me guys. Someone give me the run through. The stator makes the power/how much>then to the regulator/what is its function > then to the rect./dont know its function either> then to the battery? I am tearing the bike down and starting from scratch from the stator.
One more thing; the diagnosis from the site that helps you pinpoint probs only deals with bikes with rect/reg combos instead of seperate units correct. So none of that mapping will work for my bike having seperate rect. and regulator?
Post edited by: skydailey, at: 2007/05/30 08:48
Post edited by: skydailey, at: 2007/05/30 09:06
30 May 2007 06:01
skydailey wrote:
Now as loudhvx rolls his eyes :laugh:
My elementary understanding is:
Stator (generator) produces alternating current;
Rectifier changes ac to direct current;
Regulator governs voltage allowed into system.
And I know even less Norwegian.
One more thing; the diagnosis from the site that helps you pinpoint probs only deals with bikes with rect/reg combos instead of seperate units correct. So none of that mapping will work for my bike having seperate rect. and regulator?<br><br>Post edited by: skydailey, at: 2007/05/30 08:48
- skydailey
31 May 2007 06:22
Thank you guys so much for all your advice and help! I am re-wiring the bike and feel like with your advice it will be a success! KZ forever...........
- wiredgeorge
31 May 2007 06:43
I personally would try swapping in a new regulator before rewiring anything. The battery is boiling because the regulator isn't regulating the DC voltage level properly.
- loudhvx
31 May 2007 08:13
The regulator senses battery voltage via the brown wire. The regulator controls the power to the field-coil on the alternator. The field-coil is just a big electro magnet. This electromagnet creates the magnetism used by the stator to produce electricity (the main energy comes from the engine turning the magnetic field ). Regulating the magnetic field regulates the stator's output voltage.
The brown wire on the regulator is what you need to check. If the voltage there matches the battery, then the regulator is bad. If the voltage there is much lower than the battery, you have a wiring problem or bad connection somewhere.
1981 KZ550 D1 gpz.
Other links.
Other links.
- skydailey
31 May 2007 13:04
does the bike need to be running to do the brown wire check? Sorry, I am just learning...
- loudhvx
31 May 2007 13:09
skydailey wrote:
Not necessarily, but everything needs to be on as if the bike was running. The vibration from actually running may be a factor, though, so it's hard to say for sure.
does the bike need to be running to do the brown wire check? ...
1981 KZ550 D1 gpz.
Other links.
Other links.
- skydailey
31 May 2007 14:40
Thank you.. from my knowledge the 77 650 b1 has a seperate rectifier and regulator. Is this true? And if so why cant I find the regulator wich in the manual looks like a little square box with no fins?
- loudhvx
31 May 2007 15:31
skydailey wrote:
Look at the alternator cover (left side of the motor), are there 3 screws in a triangle pattern? If so then it is the 1977 style charging system.
skydailey wrote:
There's a chance that the factory changed over late in 1977, or a previous owner swapped out the charging system fromanother year.Thank you.. from my knowledge the 77 650 b1 has a seperate rectifier and regulator. Is this true?
skydailey wrote:
I don't know where it mounts. Maybe someone can chime in with info.And if so why cant I find the regulator wich in the manual looks like a little square box with no fins?
1981 KZ550 D1 gpz.
Other links.
Other links.
- skydailey
31 May 2007 16:27
I think we are getting somewhere now!! The bike is a 77 with the 3 triangle screws. There is 3 yellow 1 green and 1 red wire coming from stator. The green is hooked to a brown and the others strait to the rectifier. There is no regulator to be found??
- loudhvx
31 May 2007 17:04
skydailey wrote:
That is your problem. Someone hot wired the field-coil to put out maximum power all the time. You need to get a regulator.
The red is the neutral indicator wire.
Post edited by: loudhvx, at: 2007/05/31 20:06
... The green is hooked to a brown and the others strait to the rectifier. There is no regulator to be found??
1981 KZ550 D1 gpz.
Other links.
Other links.
