To the electrically minded
- BSKZ650
Re: To the electrically minded
03 Jul 2007 05:03
check the boots that hook to the plug, I found a couple of bad connections in mine, cut the wires back and installed new connectors and boots, you can get them at most part stores that have some racing items, it cured the intermittant problem
77 ltd1000, current rider
76 kz900, just waiting
- dnpurdy
05 Jul 2007 06:14
So last night my starter solenoid quit. Totally crapped out.
Got a replacement on the way, but since the main generator output connects through the solenoid, could a leaky solenoid cause some of these issues? When I look out the solenoid and started the bike by touching the two wires, the biek was able to rev without flickering the neutral light. I know the solenoid doesn't share any circuits, but could there have been crosstalk between the push button and the starter line?
(1980 KZ440-A1 sold project bike)
(1982 KZ750-N1 still stolen)
1982 KZ750-N1, my only now
- loudhvx
05 Jul 2007 06:48
It's possible there is something in the solenoid causing it to ground through the starter. It's not a direct short, but the starter can take so much current that it seems like a short to the charging system.
I say take it apart and see if the contact plunger started crumbling or see if there is some loose metal in there.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- dnpurdy
05 Jul 2007 08:14
On bike last night, I got 12V to the supply side of the solenoid, but 0 V to the starter side when the starter relay was engaged. What was weird, is it was "clicking". When I took it off it was reading about 3 Mohms across the starter terminals just as is off the bike. I took it apart, and saw nothing really weird that would have explained the suddenly failure.
However, while I was dismantling, I did break the connection from one of the switch lines to the solenoid coil, so a replacement was now mandatory.
The only thing of note was the copper bar attached to to the solenoid plunger had deep marks on it from where it was contacting the terminals, but with the amperage load going through it, I would have expected that.
I'm not optimistic that this is the last issue as I'm still blowing the 10AMP brown subcuircuit fuse about once a week. Since this is so infrequent and not consistently reproducable, I'm having trouble thinking of a way to find the bad part/wire. The brake lights (switched) run of this circuit, so I can't run around town with the fuse out too easily or with it disconnected.
Any ideas on how I can vet out each part on this circuit without putting myself in danger?
Post edited by: dnpurdy, at: 2007/07/05 11:15
- BSKZ650
05 Jul 2007 09:29
hate to say this, you may need to use the good ole Ford Wiggle test to find the bad wire
- H2RICK
- Is this a fun bike, or what!!!
09 Jul 2007 14:09
Boy, I can't wait to see how this all shakes out in the end. This thread has been the most informative thing I've read for years. Yes, I know, I should get out more.
I'd class myself as an "accomplished amateur" in electrical stuff so my "e-consciousness" has been raised several levels just reading this thread.
I have to say that you guys are certainly persistent and I offer a big tip of my helmet for your "stick-to-iteveness". Please don't quit now.
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
- dnpurdy
09 Jul 2007 14:50
Well, i'm rapidly getting to the point that the problem will fix itself as I keep replacing parts in the system!!
My new starter solenoid should be here shortly.
Post edited by: dnpurdy, at: 2007/07/09 18:21
- dnpurdy
20 Jul 2007 22:37
The saga comes full circle.
THe bike has been running alright, but I can tell it's running between 12.4 at idle and 13.5 at top, not maxing out like it should. So I decided to check out the amp situation. I grabbed my current probe after riding 20 minutes at 4000 rpms on the highway. Out to circuits -8 amps, in to battery +10 at 2000 rpm. As I revved, the amps just went up linearly.
Clearly the batt can't be right. Going to go out now, pull it, and put it on the slow battery tender charger overnight, then use hydrometer in morning when done.
Any other things that could cause that? The amp draw off the main fuse wire didn't go up after revving and after 3000 went down ( I assume due to dwell not keeping up fully anymore). So it isn't a load after the main fuse. But due to the placement of the main fuse in the circuit, that leaves only the battery, right?
- dnpurdy
21 Jul 2007 20:38
FOUND THE LAST ISSUE
Take a look -- www.davidpurdy.net/Wire.png
This was my replacement wire from regulator to battery and this had recently happened. Clearly the amps were being generated but not getting to the battery.
Finally done - whew
Finally done - whew
- nads.com
- H2RICK
22 Jul 2007 11:15
That's some nasty corrosion you've got happening there.
Glad to hear it's all sorted. Again, a tip of my helmet to you and loudhvx for your persistence. What a saga !!!
Ahhhh.....the perils of owning old bikes.....
:laugh:
Hey, nads.com, do you think ANYONE could make this stuff up ?? :laugh: :laugh: :laugh:Has this all been for real?
- MadMac74
09 Aug 2007 13:34
dnpurdy wrote:
I was thinking the ignition switch may be a cause ,also. But I was going to suggest running a switch to your low-beam lamp. My '78 650 C2 has one and that seems to help my charging issues @ Idle. I have an H4 bulb. The headlight is no effectively controlled by the highbeam switch.
By the Way , this is one of the best threads I've ever seen here, keep it up:)
Well, lack of sense wire should only have the affect of over charging. A disconnected sense wire means the regulator never switches the SCRs on to shunt to ground. The only effect that would produce undercharge with the sense wire is if I have a sense to ground short.
Hmm...interesting thought there. Sense wire is after the 30AMP main fuse, but before the bus of 10AMP subcircuit fuses. If I'm getting a small short to ground along the sense line, that could eat up wattage without necessarily pulling the 30 AMP fuse.
Also, could my ignition switch just be heating up? Could that be my "bad connector"?
'78 KZ650 C2,810 conversion,stock kz 750 cams,with a Blueprinted Head both from a '81 KZ 750. BS 34 Mikunis, Mac /Kerker 4 into 1 with custom 2" comp baffle. 3 rd owner
'02 ZRX1200R, 3rd owner
'83 XR200R, 3 rd owner
'84 V65 Sabre 3 rd owner
