Problem Solved,,,81 GPz 1100 swap in carb, need ignition help
- kano
- Not Another Bloody Limey!
Re: 81 GPz 1100 swap in carb, need ignition help
11 May 2007 07:50
did you resolve this.
i did my conversion myself.
have wiring diagrams.
anything you need to know let me know.
bs34's are a great way to go for replacing the
touchy fuel injection now she fly's ill tell ya
all the way to the speed limit here of 40 mph lol.
- turpehar
14 May 2007 08:58
kano wrote:
Not resolved yet. Travelling for work last week, and camping all weekend. I'm anxious to get this running, then on to paint. Anything you can send me to aid in the electrical would be greatly appreciated.
Thanks a heap
Post edited by: turpehar, at: 2007/05/14 12:03
lol.
Thanks a heap
- turpehar
16 May 2007 21:38
Can anyone tell me which wires should remain on the relays after disconnecting all things Fuel injection?
please see attachment.
Thanks
Post edited by: turpehar, at: 2007/05/17 00:45
Post edited by: turpehar, at: 2007/05/17 00:46
Thanks
- turpehar
- turpehar
23 May 2007 21:02
Mystery solved. It appears that I merley had a connection behind the headlight that wasn't making good contact. I was going through all the diagnostics shown in the manual and after disconnecting the 6 pin plug for the starter switch, I found the readings to be perfect. I reconnected the six pin connector and the wire to the starter solenoid, and it cranked from the button. I put some gas to it and it fired up and sounded strong.
Next step is to finish making the plates to cover the injector holes and tidy up the wiring.
Thanks for all your comments and suggestion,,,, until the next problem,,,,,,,,
