- Thank you received: 1
No 'running lights' on the rear
- eMusicMan
When I turn the bike on, all the lights are on that should be, except the rear turn signals. When I use the turn signal indicator, those work fine, but the rear light are 'off' if they arent blinking.
How do I go about troubleshooting why the 'running light' portion of my rear turn signals arent working?
I have the Clymer and the original Kawasaki Service Manual, but neither really gets into anything like this.
Thanks all,
Dustin
Post edited by: eMusicMan, at: 2007/04/17 19:05
- peachc
- harm
- Tom
- Thank you received: 13
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
- RetroRiceRocketRider
- Thank you received: 29
The rear signals on your bike should actually have 2 wires - one is power the other is ground.
If you have your heart set on having rear running lights, it's a pretty easy (albeit not always cheap) task. All you need to do is get another set of front signals, connect the turn signal wires and grounds wires as they were before, then just tie the 3rd wire into the tail light wire.
I did this on my ZN700, and it sure provides an added feeling of security at night by being more visible/distinguishable from a vehicle approaching from behind.
- eMusicMan
If you have your heart set on having rear running lights, it's a pretty easy (albeit not always cheap) task...[/quote]
Wow - so the way it is now (no running lights in the rear) is normal? I just assumed that since all cars have front and rear running lights, so would a motorcycle. Go figure!
I think I just may take on your idea as a future project... thanks!
-D
- wiredgeorge
- eMusicMan
I think your solution is a bit cleaner, but I'm still shocked to find out that the tail lights are not normally running lights.
Thanks for the tip on z1enterprises.com - I think i'll be using them as a resource for many things in the future. Honestly, too, I'm glad there is nothing 'wrong' with my bike.
In a related question - why is it that my turn signals blink faster while revving compared to idling? I would think that the regulator would be ensuring constant voltage to avoid such changes? You seem to know a lot about the electrical side of things...
Thank you,
D
- BSKZ650
- Thank you received: 14
77 ltd1000, current rider
76 kz900, just waiting
- wiredgeorge
The second possible reason is that someone changed turn signal bulbs at some dim point in the past. The OEM bulbs were Stanley bulbs and those had a rating not normally found in today's modern bulbs. If you have single filament bulbs and they are 1156 automotive type, then someone has changed them out. The Stanley bulbs were lower wattage. If the fronts turn signals have a running light integrated, and they are 1157 type, they have been swapped out for the original bulbs. The 1156 or 1157 will be stamped on the bulb on the side of the metal part.
If the bulbs have been swapped, they carry a different load to the OEM blinker relay. This relay was not designed for this load so will act funny. On a car, when adding a trailer with additional turn signals, the car blinkers will blink real fast as a result of the added load... much like yours may be from the added load of the modern bulbs. That being the case, look at your flasher relay by unplugging it. It likely has a brown wire and orange wire attached and is hanging near the battery box. If you have emergency (auxiliary flashers), then there will be two of the relays... anyway, unplug the flasher relay and note that the contacts are arrayed in an L or | _ configuration. You can buy a replacement blinker relay at ANY autoparts store. Make sure you get the HEAVY DUTY relay with the same contact configuration. It may or may not be the same shape as your OEM relay but will work as long as the contacts are the same. The HD relay will handle a wider range of electrical loads and your blinkers will flash at a normal rate. They use these on car/trucks that pull trailers when additional blinkers are used for this very reason.
- eMusicMan
This is an easy check with a multimeter. Put the meter in VDC scale... Start the bike. Put the BLACK probe (neg) on the negative battery post. Put the RED probe (pos) on the positive battery post. At idle, the reading should be ~12.5 VDC. Rev engine to 4K rpm. Reading should be ~14.5 VDC. If the readings vary; such as significantly higher, then your reg/rec is becoming marginal and should be replaced.
I think I did this before and cant recall the result - I'm going to give it another go tonight or this weekend and check into this.
The second possible reason is that someone changed turn signal bulbs at some dim point in the past...
Yesterday I noticed the rear turn signals have a 1073 (single-post) bulb in them... but I have to say that one bit of information I have not been able to find is what was the OEM bulb-type (all around) for my cycle? I think the 1073s must be the OEM for the rear, but what about the front? If you have any leads on this info - I'd appreciate it! I checked my Clymer and Kawasaki manuals without much luck.
I think I might be looking at the reg/rec replacement since it's not only the blinker. In general at night the headlight dims/brightens.
One more 'oddity' to throw your way is that when in a high-rev condition (@4k+ rpm) both the Oil and Gas lights start to light up, and get brighter as rpms increase. Is this also the same reg/rec issue?
Thank you so much for all the help. Now that the engine is working right I feel I finally can get into fixing some other parts on this bike.
Cheers,
D
- pyxen
- Thank you received: 7
A while back I was in the same position with my 550 - the Oil and Fuel lights would come on and go off, but only at higher RPM. It turned out that the (+) connection on the battery was loose and not fully juiced. Once I stopped and tightened the screw down, it was fine again.
If that happens again, I'll know it's an electrical issue. It sounds like your bike is running off the alternator only to me..at high RPM, and the bike is complaining.
I could be wrong..but that's the conclusion I came to when it happened to me. My bike eventually just cut out when I was waiting at a stop light and fidling with the highbeam/brakelights/turn signals to see if I could figure out what the hell was wrong..
84 KZ550-F2 LTD
93 ZR550-B4
