Electronic Ignition, which one to buy?
- Russ
Re: Electronic Ignition, which one to buy?
06 Apr 2007 09:08
I just bought a Dyna 2000 from Z1 Enterprises and it's the new programable one that Dyna released late 2006, it still comes with 5 different advance curves built in but if you buy their programming kit you can do your own.
www.z1enterprises.com/detail.aspx?ID=368
- Russ
06 Apr 2007 09:23
Oops! repeated post.
Post edited by: Russ, at: 2007/04/06 13:09
Post edited by: Russ, at: 2007/04/06 13:14
- loudhvx
06 Apr 2007 09:34
If it was my money, I'd get the Dyna S. The new version Dyna 2000 sounds cool, though.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- Jeff.Saunders
06 Apr 2007 10:31
The programming kit for the 2000 is more than just a wire harness, it's also the computer software to reprogram your Dyna 2000.
While this is not something most would do, the programmability is a nice feature - especially for the racing crowd as you can fine tune your timing and rev-limiter to very specific levels.
Additionally, as a tuner, you can program a Dyna 2000 for a customer and 'lock' the programming into the ignition to avoid tapering.
Z1 Ent on Facebook,
- AR15Ron
07 Apr 2007 11:48
I'm guessing the 2000 is a lot more than I actually need. I do like the idea of having a rev limitter but the advance curves and such probably not something I'll require. The Boyer system sounds cool, but still no answer from the distributer. I don't deal with companies with lousy customer service. Looks like I'll proably be ordering the Dyna soon. I should proably get all that stuff before painting the tank so I'm not pulling it on and off with fresh paint 1000 times. I do have one question though. Can you set any features of the 2000 without buying the software and cable? Does it come ready to go out of the box to work properly on my bike and set with the right rev limit? I could talk myself into that maybe
Don't suppose you have any plans of carrying that Boyer system anytime? That would proably be the deal maker hahaha. Thanks again,
Ron
Ron
- Jeff.Saunders
08 Apr 2007 08:58
The Dyna 2000 comes with a number of pre-programmed settings selectable with simple dial switches.
For a 9000 rev limit, turn the knob to 9k, for most 2-valve per cylinder inline-4's, select 4 or 5 on the advance curve knob - that's it...
Wiring takes a few more minutes than the Dyna 2000
Here's the link to the dynatek install instructions
www.dynaonline.com/english/instruct/DDK1-5_2-1_3-2.pdf
I noticed their instructions online do not show the new programmable setup - there are some minor dufferences in the setup, but it is basically the same.
Us stocking Boyer - probably no chance. We may stock Newtronics in the future if they ever come out of their funk and start producing ignition units again...
Z1 Ent on Facebook,
