charging system
  • zippoman
  • zippoman's Avatar Topic Author
charging system
22 Mar 2007 13:58
#122604
I just got a 750 motor to put in my 77 650, will I be able to use my charging system on this motor? If not can adapt my harness to use the reg/rect for this? I think the engine is a 82, thanks.
Post edited by: zippoman, at: 2007/03/23 10:34
  • trippivot
  • trippivot's Avatar
Re: chargeing system
22 Mar 2007 17:37
#122646
it'll work
  • loudhvx
  • loudhvx's Avatar
22 Mar 2007 19:01
#122680
Only if you can transfer the alternator from the 77 650 to the 750. They use different types of alternators which cannot use the same type of regulators.
  • steell
  • steell's Avatar
22 Mar 2007 19:45
#122705
And to transfer the alternator I think you have to use the 650 alternator cover.
Like Lou said, two entirely different types of alternators.
  • zippoman
23 Mar 2007 06:45
#122804
thats what I was wanting to know, if the stator and rotor will swap there shouldnt be much to it .......right? thanks
  • loudhvx
  • loudhvx's Avatar
23 Mar 2007 10:05
#122843
I really don't know if it's an easy swap or not. Hopefully someone who has done the swap can chime in. I think Mark Wing or RonKZ650 might have done the swap.
  • anarki650
  • anarki650's Avatar
23 Mar 2007 10:43
#122856
Couldn't he swap the reg/rec system? Get rid of the 77 650's two separate units and convert to using the combined unit from the 750? Then the stator and all other components of the charging system would match one another without getting into something as complex as changing the rotor on the crank.
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
  • wiredgeorge
  • wiredgeorge's Avatar
23 Mar 2007 18:43
#122948
anark650... I think your idea sounds better than swapping the alternator/stator... Whatever the swapped reg/rec looks like, the output will be a white wire going to the battery and main fuse...
  • steell
  • steell's Avatar
23 Mar 2007 20:05
#122967
That will work, keep the matching reg/rec and alternators together.
Here is why the early reg/rec won't work on the 750.
The 77 uses a different type of alternator.
Number 20 through 25 is for the B1, the alternator below that in the same pic is for the B2. I don't have the manual in front of me, but IIRC the B1 is a 77 and the B2 is a 78?
Even the B2 is different than the 750 though, single phase (two wires) for the B2 vs three phase (3 wires) for the 750.
And here is the 750.
Notice any difference?? :)
Actually posted all this because I misread the quoted post :blush:
Post edited by: steell, at: 2007/03/23 23:21
  • loudhvx
  • loudhvx's Avatar
24 Mar 2007 01:14
#123015
BTW, that picture for the 650 system actually has two complete alternators (along with the starter). One is the '77 which is the upper group. It is 3-phase, excited-field. The lower one is the '78 (there may be some overlap in the years). It is single-phase, permanent-magnet. The 750 system is 3-phase, permanent-magnet.
Either system will work, but if he wants to go to the 750 system, he'll need to buy some more stuff and have to do some wiring alterations.
I would prefer the 750 system as well, but if he has all the parts for the 650 system, and they work, it may be cheaper.
Post edited by: loudhvx, at: 2007/03/24 04:20
  • zippoman
24 Mar 2007 12:11
#123115
I think I will try finding a reg/rec for the 750 insteed of swapping the stator. I think I got a good deal on the engine, the bike it was pulled from showed 10k and paid $150.00 for it.
  • zippoman
27 Mar 2007 19:20
#124133
Im looking at a r/r with the part # they give is sh530-12 2.9 for a 83 kz 750 will this work for my engine? I looked at buykawasaki and it looks like it should but I dont see these numbers. Thanks
