Coils
  • kano
  • kano's Avatar
  • Not Another Bloody Limey!
Re: Coils
21 Feb 2007 09:10
#114139
as always a plethora of good advice from George.
  • William
  • William's Avatar Topic Author
Re: Coils
22 Feb 2007 15:56
#114550
I checked all the wiring, and fixed up the lights while I was doing it, so now I have turn singles, a small victory. So all I had left was to try a plug. I went out and got a deep socket and one new plug. I am not sure if it’s the right one but it fits so I will assume it is, a B7ES. With the new plug, I could get spark without touching the casing on cylinders 2 and 3, however I could only generate spark on cylinders 1 and 4, if I touched the plug right to the casing. The old plugs look terrible.
The spark wasn’t really grand or anything but it was about what I expected. I am losing a bit of faith in the cycle shop however they checked it with a multimeter too, but go no numbers, I had to fish around for contact and then got something.
As for the numbers, I get a 2.5 Ohms across both of them on the 200 scale, on the other end I get about 12.01 and 11.78 on the 20k scale.
If I touch it to the red wire going to the coil, then the negative battery terminal, I get 11.23 Volts, I can’t seem to get a ground on the bikes casing for anything.
So, I think the next step will be to get 4 new plugs, and I got a can of ether around the house, so I will give it a spray and see if it fires after I get some more plugs. Hopefully in the afternoon.
If It still doesn’t work, I will try this wiring mod form your site, looks a little high end for me, but I will give her a whirl.
  • tnutz
  • tnutz's Avatar
Re: Coils
22 Feb 2007 19:00
#114610
another thing that helps, good grounds. on my GPZ 1100 i went over kill, #10awg grounds to the frame engine and other odd places, bike runs a million times better. plus cleaned up and regreased all connections with die-electric grease.
  • sbodi4d
  • sbodi4d's Avatar
Re: Coils
22 Feb 2007 20:46
#114644
Not to hijack the thread, but I am going to replace the coils on my 1980 KZ1000 ST project bike, and I have looked at different sites for coils and they advertise different ohm values for them. What would my bike use?
  • wiredgeorge
  • wiredgeorge's Avatar
Re: Coils
23 Feb 2007 04:39
#114676
Steve, Do repost your question and start a new thread please! The answer isn't simple.
Back to the 750! OK, the coils are OK I think at 2.5 Ohms primary and 12K secondary. The voltage at over 11 VDC isn't bad.
Seems you have spark on 2/3 and 1/4. The plug type is wrong... someone was getting sooty plugs and put in a set one heat range hotter to try and keep the plugs clean. I would suggest you do the coil repowering mod suggested on our web site and some new B8ES NGK plugs. Last, I would recheck the plug wire seating inside the coils and make sure the plug caps are tight on the plugs. I believe the caps you are using require the little screw-on nuts on the plugs.
