I want to add these 55w driving lights
  • 81Red750
  • 81Red750's Avatar Topic Author
Re: I want to add these 55w driving lights
05 Jan 2007 16:15
#103604
  • 81Red750
05 Jan 2007 16:15
#103605
  • 81Red750
05 Jan 2007 17:00
#103620
Well. I only added a single light, under the fork brace. In preliminary fiddlin' during the daytime, but in a closed garage, it seems to "throw" the beam further than the stock bulb.
After spending the last half hour aiming and playing with the new light, I can give a decent early synopsis. The beam is def. wider than the stock headlight, but after I aimed it, it was equally far, but dimmer at the farthest point. but it sends a wide beam that 'fills out' the stock beam.
Basically, at low beam it is somewhat worthwhile. However, at hi-beam, it is like having an additional low beam to fill out the near-field while throwing a far beam.
In short, it's OK if you spend <$15 like I did, Otherwise, dont spend the cash on cheap car driving lights..
  • 81Red750
05 Jan 2007 21:54
#103677
2nd update: I went out to a dark hwy and did 75 in the pitch black. The 2nd light made a huge difference! It just blossomed the reg beam and made it much like my buddy's '06 Z750s with it's factory duals.
All in all I am please excepting 2 things:
1. I ran the batt down while testing and running around town
2. The stupid switch will not stay put with the double sticky tape. Besides, I gotta relocate to somewhere more convenient.
  • loudhvx
  • loudhvx's Avatar
06 Jan 2007 17:40
#103828
It looks pretty cool there. For less than $15 it's a good deal plus you have a spare. Are you sure the fender won't come up and smack the light on a heavy bump?
  • 81Red750
06 Jan 2007 17:50
#103831
Well, I really hope I dont hit a bump that requires 6" of suspension travel! :blink:
I fabbed up a switch holder that resides just east of my left grip out of plate aluminum and a push button switch instead of the rocker. I then weather/splashproofed it. Pics to come tomorrow. It's pretty trick, if I do say so myself. :P
  • Biquetoast
  • Biquetoast's Avatar
  • King Jeremy The Wicked
06 Jan 2007 18:21
#103839
81Red750 wrote:
Well. I only added a single light, under the fork brace....
Yep, that's where I have my round one. See below. And in reply to your concern about fork travel... fahghettaboudit!
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
  • OKC_Kent
  • OKC_Kent's Avatar
06 Jan 2007 18:34
#103840
Hey biquetoast,
I see you have a beaded seatpad like the one I have, how do you like it?
OKC
Cashion, OK
78 KZ650 B2 85,000+ miles
  • 81Red750
07 Jan 2007 16:58
#104015
well sh-t, it nicked the top o' the fender and scratched/dented it a bit. Then I took the time to do something I've meant to - check the fork air pressure....0lbs. I bumped it up to 29lbs (25-36 spec) and all of a sudden my forkdive is a memory.
But back to the lights..
Here's the scoop: I added the switch below as I described above, but it nicked the tank at bar lock. That and it was precarious to the wiring when that happened. Stay tuned for the fix...
  • 81Red750
07 Jan 2007 16:59
#104016
here's nthe new location, which is easier to hit with eyes on the road, more likely to stay dry and all around cool:
  • 81Red750
07 Jan 2007 17:00
#104017
view 2
  • 81Red750
07 Jan 2007 17:00
#104018
view from a fly's perspective:
