Headlight passed away
  • OKC_Kent
  • OKC_Kent's Avatar
Re: Headlight passed away
25 Dec 2006 09:13
#101686
Here is the link for a vibration resistant H4 halogen bulb at JCWhitney.
tinyurl.com/uzay9
Cashion, OK
78 KZ650 B2 85,000+ miles
  • JMKZHI
  • JMKZHI's Avatar
Re: .
27 Dec 2006 07:32 - 03 Dec 2008 13:42
#101961
del
Last edit: 03 Dec 2008 13:42 by JMKZHI.
  • NIGHT RUNNER
  • NIGHT RUNNER's Avatar
27 Dec 2006 08:23
#101968
Go to e-bay or local parts store and buy a 86-92 vw golf single round headlight (about 15.00usd),these are flat and look goos ,then get a blue xenon halogen bulb and you will be as bright as noticeable at night ,if your wiring gets hot go with a relay to more amps ,your wiring will not be hurt.B)
  • 893cv
  • 893cv's Avatar
27 Dec 2006 20:15
#102133
You should only use a motorcycle spacific headlight. The dispersion pattern is different then a car headlight. I have been using Bosch motorcycle H4 type headlights for years with very good results. I also always upgrade the electricl system with a pair of relays and 12 guage wires for both the powerd side of the system and the ground side too. Parts Unlimited sells the correct Bosch bulb so your local dealer should be able to get you the light you need.
1980 kz1000 LTD
1978 Z1R
  • Bluemeanie
  • Bluemeanie's Avatar Topic Author
29 Dec 2006 06:40
#102330
Checked out the light at JCW and it seems perfect! Less than $20 too! I'm not much into electrical so will this halogen swap right in with no elect problems?
  • yakimasy
  • yakimasy's Avatar
31 Dec 2006 00:13
#102584
OKC_Kent wrote:
As I heard somewhere, cars have two headlights and the beam pattern is supposedly different than a cycle headlight. The cuts in the glass spread the light different for a bike with cycle headlight.
Now, I never ran a car headlight in my bikes so I can't say there is a difference. If steell says it's fine then I believe it.<br><br>Post edited by: OKC_Kent, at: 2006/12/24 14:58
I read somewhere that automotive lights can't withstand the vibration of the bike and do not last as long..
This may have been evil propaganda that persuades people to buy $70 KZ headlights off ebay and not $7.21 headlights from JEFF at Z1 enterprises.... I'm going off the assumption that this is a 7" fit?!?!
PS.. bought one from Jeff... works perfect.....:P
Post edited by: yakimasy, at: 2006/12/31 03:17
  • Bluemeanie
31 Dec 2006 06:38
#102598
Yes it is 7" (my wife says it looks smaller :woohoo: ) Does the halogen affect my wiring at all? Don't want to have to "rewire" anything. I'm a plug and play kinda guy.
  • OKC_Kent
  • OKC_Kent's Avatar
31 Dec 2006 08:08
#102607
If you stick with the 55/60 watt light you will be fine with the stock wiring. If you ever decide to go to the 80watt and higher bulbs, then I would rewire the headlight circuit with thicker wire and use a relay.
But really, the 55/60 bulb will be amazing in brightness if all you rode with before was the stock 35w light.
Cashion, OK
  • Bluemeanie
31 Dec 2006 08:27
#102615
are you talking about the 55/60 "Halogen"?
