I just reinstalled the carbs after a friend did an untrasonic cleaning on them and supposedly reset the fuel screws to factory settings. Bike starts OK but idle goes up to 4 thousand. If I rev it, idle will drop to a thousand or so. I took it for a ride, continually revving it to bring idle down. Got it warmed up, tried to set idle. Bike was idling about 900 stumbling not wanting to run. Turned idle adjuster, nothing happened, turned it again, nothing, turned it again, idle rose to 5000. Turned idle down, nothing happened, turned again, nothing, turned again idle dropped to under 1000. I loosened both throttle cables on both ends to take the cables out of the equation. No difference, BUT I noticed when I put the choke on it runs normal. I should add I just changed the exhaust from 4 in 2s to reproduction 4 in 4s and I didn't change the jetting. Bike ran pretty good before I had carbs cleaned. I actually only pulled them to check the float levels and figured I'd have them dunked while they were off. Any insight and or advice will be greatly appreciated.
Also... I did check for exhaust leaks just with my hand and listening and doesn't appear to have any leaks. I did change the copper crush gaskets.
