loudhvx wrote:
old_kaw wrote:
loudhvx wrote: Over the years I've become more and more averse to chemicals... hence I'd rather cut and weld. Welding is way more "fun" at any rate... though it is not without fumes either.
Soooo, your solution is to cut the gas tank open and scrape the kreme off then weld it back together? Sounds reasonable. LOL ::
Yes, simple no?
It'll probably never happen, but if done properly, I think it can be more thorough, as it seems any left over liner is going to gum the carbs, and I'm already sick of cleaning liner gunk out of the carbs. Also, i'm hoping if the cuts are placed in the right areas, it won't affect the top-side factory paint job, which is in very nice condition. What will stripper or MEK do to paint? I hate painting ... more chemicals and a bunch of tools I don't have and don't want to have.
I used to have a girlfriend that would over complicate EVERYTHING, then do nothing because it was too much work. LOL
Simple NO. lol
Of course, I'm sure this is only for "what if?" purposes, since very few have OEM paint that is pristine enough to save. Let alone, the welding equipment and skills necessary. In the end, you have a tank with scratched up OLD paint that looks like crap on a welded up tank.
When I decided to remove my liner, I had also decided it was time to put some nice paint on the bike at the same time. Of course, if you are careful enough, and really really really want to save a paint job, it would require the most careful masking , covering and pouring like no one has ever seen. I even put screws in the tank and rotated it in both directions ~1/2 hour each way, packed into my clothes dryer to make sure I got everything out.
Don't try this at home!
Of course MEK and stripper WILL ruin any paint it gets on. so will a welder and cutting torch, and rolling it around on a bunch of welding and grinding debris, to the point that saving the paint will no longer be an issue. . Considering that MINE had a full on " custom" rattle can paint "improvement" . Along with the KOOL kreme job. The paint is of usually of no consideration at this point.
Could you post a few pics of the tanks that you have done this to? Inquiring minds want to know.
Attachment not found
I foresee a very lucrative future doing tank coating removal for the patrons on kzrider. lol
