idle 19 May 2017 21:57 #762259
  • tthunderdan
  • tthunderdan's Avatar Topic Author
  • Thank you received: 15
On my newly aqquired 83 kz1100 the motor does not snap back to idle like I feel it should. I notice it mostly coming to a stop. Another thing I notice is the choke knob want to pop back out to almost first position, which I push back in and it idles down ok then. Other than that the bike (although cold blooded) starts and runs very well. Any ideas to the cause of this?
Dan
Dan from Slippery Rock PA,
83kz1100a
83spectre 1100
75 Yamaha DT400
75 Yamaha DT175
80 Yamaha MX80
81 Suzuki TS100
idle 20 May 2017 04:18 #762261
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2675
Bad cables?
If the idle is hanging and not settling down quickly that could be an air leak. Replace carb boots on the head and possibly the boots at the back of the carbs too. Some people spray stuff on the carbs and listen for engine speed changes as a way of finding vacuum leaks but in my experience that method is not 100% reliable.
idle 20 May 2017 07:18 #762278
  • tthunderdan
can you imagine what would make that choke knob work back out to about the first sto?
83kz1100a
83spectre 1100
75 Yamaha DT400
75 Yamaha DT175
80 Yamaha MX80
81 Suzuki TS100
idle 20 May 2017 07:28 #762283
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2621
Can't help with what we can't see.
idle 20 May 2017 07:37 #762285
  • tthunderdan
ok
83kz1100a
83spectre 1100
75 Yamaha DT400
75 Yamaha DT175
80 Yamaha MX80
81 Suzuki TS100
idle 20 May 2017 08:22 #762290
  • SWest
  • SWest's Avatar
  • 10 22 2014
No slight intended, pics help.
idle 20 May 2017 11:21 #762301
  • tthunderdan
I understand. No problemo, it is awkward to get a vid of it popping out by myself and reving it. I have included a pic of the choke set up.on this. I lnow the knob is broken off. Please look at this and see if it is correct. Should the little spring be on the outside of that bracket and helping to hold it in? My manual isnt real clear in its pic of choke knob. setup. And what is the thumbwheel in the center of the 4 carbs coming out the back of carbs? Kinda hard to see.
Dan
Attachment not found
83kz1100a
83spectre 1100
75 Yamaha DT400
75 Yamaha DT175
80 Yamaha MX80
81 Suzuki TS100
Last edit: by tthunderdan. Reason: pics
idle 20 May 2017 12:45 #762306
  • SWest
  • SWest's Avatar
  • 10 22 2014
That's the idle adjustment screw. Looks liike you're missing the snap ring on the choke plunger.
Last edit: by SWest.
idle 20 May 2017 12:57 #762308
  • SWest
  • SWest's Avatar
  • 10 22 2014
idle 20 May 2017 13:16 #762310
  • tthunderdan
and the snap ring on my setup would be directly under my missing black knob?
83kz1100a
83spectre 1100
75 Yamaha DT400
75 Yamaha DT175
80 Yamaha MX80
81 Suzuki TS100
idle 20 May 2017 13:39 #762314
  • SWest
  • SWest's Avatar
  • 10 22 2014
No eBay APP ID and/or Cert ID defined in Kunena configurationHere's a pic. No snap ring I can see.
idle 20 May 2017 14:19 #762319
  • tthunderdan
and the u shaped little steel chanel piece looks strait on the ebay one compared to my bent u shaped little steel channel piece. hmmmmm
83kz1100a
83spectre 1100
75 Yamaha DT400
75 Yamaha DT175
80 Yamaha MX80
81 Suzuki TS100
