Mikuni VM 33 Carbs 07 Sep 2017 20:26 #770575
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
  • Thank you received: 2620
Mikuni VM 33 Carbs 23 Sep 2017 15:47 #771532
  • SWest
  • 10 22 2014
I'll probably go with 40-45 pilots.
Mikuni VM 33 Carbs 23 Sep 2017 17:50 #771543
  • SWest
  • 10 22 2014
I went ahead and ordered them. I'll get my jets at Chaparral.
Mikuni VM 33 Carbs 23 Sep 2017 18:33 #771546
  • SWest
  • 10 22 2014
Better
Mikuni VM 33 Carbs 23 Sep 2017 19:50 #771550
  • SWest
  • 10 22 2014
I think I'll keep it here for a few hundred miles.
Mikuni VM 33 Carbs 04 Oct 2017 19:08 #772372
  • SWest
  • 10 22 2014
Got my .9 air jets and 45 pilot jets. Plugs still look a little rich on the bottom. Gotta put them in, change the needles to the center position then re sync the carbs. This time I'll bench sync them with a 7mm drill bit. Should be easier to vacuum sync them and hopefully the adjustment screws will be more even this time. Should take all morning.
Mikuni VM 33 Carbs 05 Oct 2017 06:47 #772379
  • daveo
  • daveo's Avatar
  • Premium Member
  • Thank you received: 632
Steve, does your setup employ a filter in the air box?
My velocity stacks are wide open inside the air box, and I'm currently experimenting with a piece of Ramair filter media stretched over the intake snorkel opening, held in place with a zip-tie.
The engine seems to prefer the restriction to having more air available with the snorkel-cover removed. :blink: But there is also filter media that seal the stacks at the carburetor side, where more air must be getting pulled through as needed.
1982 KZ1100-A2
Last edit: by daveo.
Mikuni VM 33 Carbs 05 Oct 2017 07:19 #772381
  • SWest
  • 10 22 2014
I have a K&N filter and added six vents on the back. Had to to the 127.5's. Starting all over again.:whistle:
Mikuni VM 33 Carbs 05 Oct 2017 08:26 #772385
  • daveo
  • daveo's Avatar
  • Premium Member
Thankfully, it's all a PITA labor of love...
:dry:
1982 KZ1100-A2
Mikuni VM 33 Carbs 05 Oct 2017 17:13 #772400
  • SWest
  • 10 22 2014
I may have to raise the needles a notch.
Mikuni VM 33 Carbs 05 Oct 2017 21:07 #772411
  • SWest
  • 10 22 2014
I'll run it a while.
Mikuni VM 33 Carbs 07 Oct 2017 19:37 #772499
  • SWest
  • 10 22 2014
Seems a little lean now. Running hotter too.
