TOPIC: Jet needle improves acceleration.
Jet needle improves acceleration. 22 Nov 2012 04:52 #559584
  • bountyhunter
  • bountyhunter's Avatar
  • Member
  • Member
  • Thank you received: 337
baldy110 wrote:
I like it. In fact I will hang this quote in my garage.
I still like the sign I saw back in the deep part of the shop at Grand Prix Kawasaki:
SHOP LABOR RATES:
Basic Rate: $60/hr
If You Watch Me Work: $150/hr
If You Worked On It First: $300/hr
Jet needle improves acceleration. 22 Nov 2012 07:59 #559588
  • donthaveakawman
  • donthaveakawman's Avatar
  • Visitor
  • Visitor
SHOP LABOR RATES:
Basic Rate: $60/hr
thank you, that is funny
Jet needle improves acceleration. 06 Jun 2013 09:01 #591052
  • baborz72
  • baborz72's Avatar
  • Member
  • Member
  • Not enough hours!
  • Thank you received: 1
Hi. I have this very same bike with thew very same problem.I put pods on and fabbed a 4-2-1 header. It is very lean during the mid and was lean on the top, but not as bad. Ran a 125 mainjet and she's too fat. Going back to a 120 main and going to run a different needle. I turned my needles down by hand and it got significantly better, but I screwed the off-idle up. I am convinced that I am on the right track with a needle swap. Going to run a 5FL14. I will post the results.
It'll go...or...It'll blow!
Jet needle improves acceleration. 06 May 2014 19:09 #631593
  • nads.com
  • nads.com's Avatar
  • Member
  • Member
  • Thank you received: 19
Does it idle smooth and steady? Are all plugs th same color now? You never said how It runs at idle now, was just wondering if you have a plug cap that is bad.
The following user(s) said Thank You: Tomolu5
Last edit: by nads.com.
Jet needle improves acceleration. 18 Mar 2016 15:37 #716073
  • car5car
  • car5car's Avatar
  • Banned
  • Banned
  • Thank you received: 20
Patton wrote: For carb tuning considerations, if not already aware ---
Main jet size has no effect on air/fuel mixture until after 3/4 throttle, and has most effect at wot where the jet needle is high enough in the needle jet to allow all mixture available from the main jet to pass through the needle jet.
Jet needle taper and position in the needle jet (plus slide cutaway) governs air/fuel mixture from 1/4~3/4 throttle.
The pilot jet governs air fuel mixture from idle~1/4 throttle.
Up to 1/4 throttle position on large Kaw fours produces a surprisingly brisk road speed.
There is a progressive transition as the jet needle takes over from the pilot jet, and another progressive transition when the jet needle thereafter surrenders to the main jet (as the main jet supplies the needle jet absent limitation by the tapered jet needle).
Pods are typically more difficult to tune (than the stock air box) over the entire range of carb operation.
Good Fortune! :)
Thanks, very interesting about transition from needle to main.
96 Yamaha Royal Star
82 Yamaha Virago 920
Jet needle improves acceleration. 25 Mar 2016 06:37 #717256
  • zirafin
  • zirafin's Avatar
  • Member
  • Member
i have ?
kz550 b2 .tk22
i tace out jet needle ( just 1 to look ) its ok o i need to pot Needle Retaining E Clip lower ??
Last edit: by zirafin.
Jet needle improves acceleration. 27 Mar 2016 06:52 #717554
  • loudhvx
  • loudhvx's Avatar
  • Thank you received: 1097
Never mind, old thread.
To Zirafin, probably best to keep posts for your bike on your main discussion thread, until the problems are solved. It's easier to help that way.
Last edit: by loudhvx.
Jet needle improves acceleration. 25 Apr 2018 22:27 #782385
  • Tesk
  • Tesk's Avatar
  • Member
  • Member
  • Thank you received: 0
My mechanic suggested me to buy a 140 jet because I recently bought air pods and my exhaust system is a 4 to 1. My motorcycle is a KZ 750 ltd 1982. Is 140 jet a good decision or nah?
Jet needle improves acceleration. 26 Apr 2018 04:20 #782394
  • spudbudy
  • spudbudy's Avatar
  • Member
  • Member
  • Kick it like you mean it
140 is way too big I would not go over 120\125 max. Pods are extremely hard to tune. Good luck. If you want better performance go with bigger carbs
78 KZ 650B2. Vetter faring, Dyna S, Dyna Green coils, WG coil mod,AGM Battery, VM26SS carbs, Pilot jet 15, mains 110, jet clip #2 shimmed position, Modified stock air box, stock air filter, Kerker 4 into 1 with stock baffle. currently 48,785 miles. :-) and climbing daily.:-)
The following user(s) said Thank You: Tesk
Jet needle improves acceleration. 26 Apr 2018 06:35 #782398
  • Tesk
  • Tesk's Avatar
  • Member
  • Member
spudbudy wrote: 140 is way too big I would not go over 120\125 max. Pods are extremely hard to tune. Good luck. If you want better performance go with bigger carbs
What do you mean by bigger carbs? Is there a modification I dont know about lol? What if I want the less problem possible
Jet needle improves acceleration. 26 Apr 2018 06:49 #782400
  • TexasKZ
  • TexasKZ's Avatar
  • Platinum Boarder
  • Platinum Boarder
  • Thank you received: 789
If you really want the fewest problems, put the factory intake system (air box, filter, and all) back on. If you have a 750 twin with BS34 carbs, they are notoriously difficult to tune for individual filters, and you will likely loose a little performance along the way.
Unless you are going to add high compression pistons, ported head, high performance cams and bigger carbs, there really is no point in individual filters. The stock setup flows as much as the stock engine needs.
Jet needle improves acceleration. 26 Apr 2018 07:03 #782402
  • Tesk
  • Tesk's Avatar
  • Member
  • Member
Actually I have a kz 750 ltd 1982, heihin carburetors. But Im so fucking confused because of leaking fuel to the airbox. And when I open the carburetor the float valves mooves freely, have already cleaned EVERY part of the carburetor, the only thing I think it is, is a dirty diaphram inside the petcock because of a dirty gas tank.
