- Thank you received: 542
V/H sidewinder Z1 with drum brake
- z1kzonly
for the rear brake pedal - footpeg adjustment.
The engine is not in the frame yet. So I can't align the header yet.
Just planning stuff in my head. Have everything I would need to cut, bend, weld. Then a re-chrome to make it look good.
Thanks for any pictures.
Marty
- vernons
- Thank you received: 12
when you get this figured out for the brake pedal i would buy a modded brake pedal if you could fab an extra one???
look forward visiting?? my email is vernons9358@sbcglobal.net
- PLUMMEN
- Thank you received: 104
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
i think you normally have to run brake pedal over footpeg to clear it
Yes Sir! That's the correct answer.
- z1kzonly
Is visualization a word? Or did I just make it up?
Like George W used to make up words?
- kzz1p
- oldkaws4ever
- Have no regrets...... You only live once.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- School Teacher
I will get some pics of my friends he went under and used stock stuff and an torch to bend the pedal. He used the center stand tabs to weld a pivot axle to. The pic will be worth a thousand words when i get it. he is the knight rider on here.
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
- Dice
1975 Z1B
- oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- kzz1p
- kzz1p
