KZ clutch basket rivets
  • asphalt900
  • asphalt900's Avatar
Re: KZ clutch basket rivets
28 Feb 2024 08:33
#895695
Didn't know that? I know Matchless/Norton and others shared British tech before they went defunct. The Snorting Norton, here's a Commando 750 gearbox i'm finishing up for a 1973 restoration. Sooo different than the Asian bikes! Think i have all the Andover tools and Whitworth tools for just a one-off endeavor i'll ever need again, but ya never know ha.
  • Southpaw
  • Southpaw's Avatar Topic Author
28 Feb 2024 15:57
#895721
Well that didn't go as planned, got the rivets welded in but I got hairline cracks, tig welded it with ER80 S. Anyone know the secret to welding these? Hoping Jay might chime in and share his process??
  • zed1015
  • zed1015's Avatar
28 Feb 2024 16:27 - 29 Feb 2024 02:26
#895722
Welds look burnt.
Probably not enough sheiding gas which has led to excess oxygen causing overheating, over expansion and enbrittlement.
Maybe to many amps too.
Last edit: 29 Feb 2024 02:26 by zed1015.
  • Southpaw
28 Feb 2024 16:46
#895723
Tig was set at 25 lpm, furick #10 pyrex cup
  • Nessism
  • Nessism's Avatar
28 Feb 2024 20:16 - 28 Feb 2024 20:17
#895728
Welder friend used silicon bronze type welding rod on my 750 basket.  He welded each rivet in segments, working his way around the basket.
[img
P1020585 by nessism , on Flickr
Last edit: 28 Feb 2024 20:17 by Nessism.
  • Southpaw
29 Feb 2024 10:33
#895754
Hmm, never thought about Tig Brazing them in........
  • asphalt900
29 Feb 2024 10:46
#895756
Who got nutty with the drill bit lightening the basket? That's probably where your hairline cracks came from, no dispersion material to relieve the byproduct of heat when welding.
The following user(s) said Thank You: Nessism, sf4t7
  • Nessism
  • Nessism's Avatar
29 Feb 2024 13:41
#895761
In the Suzuki GS world, drag racers would sometimes scatter clutch assemblies because the backplate would shatter, and/or the basket, although this was much less common.  That clutch assembly full of holes throws a red flag to me, although, admittedly, I'm not a draw racer, and I don't know big KZ's very well.
  • Vinsky
  • Vinsky's Avatar
29 Feb 2024 19:19
#895770
I used 304 ss to weld my clutch basket. Sil Brz would be a good choice too.
Vinsky
  • Injected
  • Injected's Avatar
01 Mar 2024 08:16
#895783
I don't think you need to be worried about some tiny cracks, you mentioned your planned engine build was going to yield about 140 HP.
It takes a lot more HP than that to rip apart a KZ clutch hub. I was told stock KZ stuff starts to break at the 400 HP level.
You also need to remember the weld material is now stronger than the material it is bonded with. It would take some crazy power to rip that assembly apart even with the lightening holes.
1978 KZ650B2 modified project
  • Southpaw
05 Mar 2024 09:23 - 05 Mar 2024 09:26
#895999
That would be me that lightened the clutch assembly, It's not unusual to do that, I doubt it has anything to do with the cracks,
Last edit: 05 Mar 2024 09:26 by Southpaw.
  • Injected
  • Injected's Avatar
06 Mar 2024 06:55 - 06 Mar 2024 06:56
#896034
I have never heard of a KZ clutch coming apart at the drag strip. The main carnage happens to pistons or drive chains, I have seen some drive chains break and it can cause case damage in front of the drive sprocket.
I got rid of the stock chain guard at the front sprocket, I made a stronger thicker steel guard in case the chain lets go (grey strap) This protects my fuel pump and lines but also the lower case.
The stock trans door cover casting breaks too easy when the chain comes apart. This is on a 650 but you can do the same thing on a 900/1000.
Last edit: 06 Mar 2024 06:56 by Injected. Reason: sp
