140/60/18 on stock 3.00" rim
  • kawi810
  • kawi810's Avatar Topic Author
Re: 140/60/18 on stock 3.00" rim
02 Mar 2016 04:09
#713373
original owner of a 1984 gpz 750
1985 turbo 750 stock, being restored.
1984 gpz 750 with 810 cc wiesco's megacycle cams(471-10) 34 mm flatslides v&h pipe ported head dyna ignition. bottom end, crank case from turbo 750 and sprockets.
  • kawi810
02 Mar 2016 04:10
#713374
  • kawi810
02 Mar 2016 04:11
#713375
  • kawi810
02 Mar 2016 04:11
#713376
  • riturbo
  • riturbo's Avatar
02 Mar 2016 05:41
#713387
That came out nice . What bike is that going on ?
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
  • kawi810
02 Mar 2016 05:48
#713391
its going on my 810 cc dragbike but i can put the swingarm and lowering links on my 750 turbo .
  • kawi810
02 Mar 2016 05:50
#713392
i was thinking going with a wider rim but i just use the stock one for now.this way i do not have to offset the sprockets.
  • zukdave
  • zukdave's Avatar
02 Mar 2016 09:28 - 02 Mar 2016 09:30
#713439
I run the 3.5" rim on a KZ1000 disk hub using KZ650 flat front sprocket
and a 530 chain. I made some ring's pressed on the bearing's to use the GPz wheel bearing's in the KZ1000
hub and some spacer work and it bolt's on using the GPz axle.
I also turned down the disk to work with the GPz brake setup.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Last edit: 02 Mar 2016 09:30 by zukdave.
  • kawi810
02 Mar 2016 09:47
#713443
maybe i should do the same .do you have any problems with the spoked rim ?
  • kawi810
02 Mar 2016 09:51
#713445
the reason i ask is i thought some one on here said its not a good idea. but with all those passes on that set i don't see a problem
  • zukdave
  • zukdave's Avatar
02 Mar 2016 17:30
#713527
At our power level I don't see an issue running a spoke wheel. I wouldn't run one on
a 200+ hp Busa .
If you do the F/B thing check out all the spoke wheel bike's on here.
www.facebook.com/groups/184003191795200/
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
  • kawi810
02 Mar 2016 17:50
#713533
just checked it out ,i think all the bikes had spoked rims .i bet they never had a problem.
