Let's see YOUR drag bike !
- 750 R1
Re: Let's see YOUR drag bike !
18 Feb 2022 15:31That would have been fun on right hand corners !!
- Southpaw
19 Aug 2022 09:18 - 19 Aug 2022 13:05
Last edit: 19 Aug 2022 13:05 by Street Fighter LTD.
- Dragbike_Mike
20 Aug 2022 13:12 - 20 Aug 2022 16:43
In reading through this thread, I realized that I hadn't posted a pic of me and my dragbike. So, here you go - a pic taken in the pits at Indianapolis Raceway Park, August 1996, at the Prostar Thunder Nationals. I was bit lighter then (by about 10 lbs) and, gee, no gray hair!!! Some great memories. Seems like yesterday...
Mike
Mike
Last edit: 20 Aug 2022 16:43 by Dragbike_Mike. Reason: typo correction
The following user(s) said Thank You: Nessism, riturbo, Street Fighter LTD, slayer61
- tomsbadkz
26 Mar 2023 07:39 - 26 Mar 2023 07:40
Hoping to get to Mason/Dixon dragway in the spring. Traction is gonna be the issue....... and rider ability.
1977 kz1327
Cavanaugh Head 38.6/33
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
Last edit: 26 Mar 2023 07:40 by tomsbadkz. Reason: pic
The following user(s) said Thank You: Street Fighter LTD, Scirocco, urankjj, Dragbike_Mike, Wookie58
- Injected
27 Mar 2023 17:17 - 27 Mar 2023 17:20
1978 KZ650B2 modified project
Last edit: 27 Mar 2023 17:20 by Injected.
28 Mar 2023 12:20
How about some pics of the whole bike injected, looks like a beast
- Injected
28 Mar 2023 13:10 - 28 Mar 2023 13:16There is not much to see right now, had a issue torquing down a couple of cylinder head nuts late last year so stopped and covered it. Had too much on my plate to troubleshoot the issue. Going to dive into it soon.How about some pics of the whole bike injected, looks like a beast
Here is where its at :
Here is what it looks like complete (PO) :
Got rid of the yellow paint and went flat black. Bought it as a roller and built my own 1327 engine, had to completely trash the wire harness on it and redid the whole thing from scratch (not that there are many wires on it) 7 inch slick, 5 speed hand clutch, lock up, and kick start with a manual retard.
Last edit: 28 Mar 2023 13:16 by Injected.
The following user(s) said Thank You: urankjj, Dragbike_Mike, Wookie58
- urankjj
28 Mar 2023 15:50It's gonna be sweet I don't know if it's the same issue but when I built the Honda motor in my Harris many years ago I had one that wouldn't tighten. The stud was pulling out of the crankcase like a cork from a wine bottle, a so called "toolmaker" then made a complete dogs arse of helicoiling it (the stud was at an angle) I ended up having to go out to 14mm and get a sleeve made to screw into the crankcase to take the stud) as yours hasn't been butchered if it is the same issue I guess a "Timesert" would probably get the job done.There is not much to see right now, had a issue torquing down a couple of cylinder head nuts late last year so stopped and covered it. Had too much on my plate to troubleshoot the issue. Going to dive into it soon.How about some pics of the whole bike injected, looks like a beast
Be lucky
- Injected
29 Mar 2023 15:53I am hoping I can avoid tearing it down. The guy who ported the head has seen similar issues on other drag bikes and has other suggestions to try first. Nothing worse than being hours away from first fire up and come up on a issue like this.It's gonna be sweet I don't know if it's the same issue but when I built the Honda motor in my Harris many years ago I had one that wouldn't tighten. The stud was pulling out of the crankcase like a cork from a wine bottle, a so called "toolmaker" then made a complete dogs arse of helicoiling it (the stud was at an angle) I ended up having to go out to 14mm and get a sleeve made to screw into the crankcase to take the stud) as yours hasn't been butchered if it is the same issue I guess a "Timesert" would probably get the job done.There is not much to see right now, had a issue torquing down a couple of cylinder head nuts late last year so stopped and covered it. Had too much on my plate to troubleshoot the issue. Going to dive into it soon.How about some pics of the whole bike injected, looks like a beast
Be lucky
The PO (ugly yellow paint job) went 9.20's with a 1075 motor (custom 30mm Lectrons) The original builder had a 1327 motor and went 8.60's in 1980.
29 Mar 2023 16:11that will get the blood pumpingI am hoping I can avoid tearing it down. The guy who ported the head has seen similar issues on other drag bikes and has other suggestions to try first. Nothing worse than being hours away from first fire up and come up on a issue like this.It's gonna be sweet I don't know if it's the same issue but when I built the Honda motor in my Harris many years ago I had one that wouldn't tighten. The stud was pulling out of the crankcase like a cork from a wine bottle, a so called "toolmaker" then made a complete dogs arse of helicoiling it (the stud was at an angle) I ended up having to go out to 14mm and get a sleeve made to screw into the crankcase to take the stud) as yours hasn't been butchered if it is the same issue I guess a "Timesert" would probably get the job done.There is not much to see right now, had a issue torquing down a couple of cylinder head nuts late last year so stopped and covered it. Had too much on my plate to troubleshoot the issue. Going to dive into it soon.How about some pics of the whole bike injected, looks like a beast
Be lucky
- Injected
31 Mar 2023 17:09 - 31 Mar 2023 17:24
Need to pull this one out this Summer as well...
I was working on it last the Summer before Covid hit, did a bunch of changes to it. Ported the head a bit more and installed some smaller fuel nozzles.
Want to get it running and then assess if I want to revert back to a self start (kick or button) which might mean going back to running gasoline.
Last edit: 31 Mar 2023 17:24 by Injected.
The following user(s) said Thank You: Dragbike_Mike, Wookie58
