- Thank you received: 229
Drag strip trip.
- zukdave
08 Sep 2017 21:03 #770626
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Replied by zukdave on topic Drag strip trip.
Local shop is hosting a dyno day for one of the local sport bike group Sunday with a ten bike limit
$50.00 buck's for 3 to 5 pull's their cool with my KZ so I'm in at number five.
I want the A/F ratio print out so I can really see what the carbs are doing more than the hp number.
As for the hp.number tell me what you think it will make at the tire ?
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
01 Nov 2017 09:42 #774098
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Going to take the bike to the track this weekend at the dyno day bike made 87 hp at the tire with way rich jetting
so I've rejetted and with a few test hit's on the street it seem's to be pulling harder and getting to the shift point quicker
so that say's the power is up some.
revivalcycles.com/pages/the-twist-off
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- KZB2 650
- Thank you received: 265
01 Nov 2017 12:59 #774101
by KZB2 650
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Replied by KZB2 650 on topic Drag strip trip.
Where were you and where are you now with the mains? I just went from 115s to 117.5s after draining the carbs and putting it away for winter. I'm quite a bit smaller but the cooler weather I run in 70 to 80 degree's should make up one size I'm think in.
1978 KZ650 b-2
- zukdave
01 Nov 2017 15:52 - 01 Nov 2017 15:52 #774110
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
20 pilot's 122.5 main's and needle in the mid.notch but my motor's 110 cc bigger with a ported ZX750A1 head and the
big tube header so I'm moving a lot more air then you.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Last edit: 01 Nov 2017 15:52 by zukdave.
- KZB2 650
02 Nov 2017 10:17 - 02 Nov 2017 10:21 #774132
by KZB2 650
1978 KZ650 b-2
So the 20 pilot and 122.5 mains are the leaner jets that you changed out after the dyno showed you way to rich? 87 HP sounds good ...... with you leaning it a little and a big cam you'd have to be in the low 90s.:woohoo: That Dyna 2000 is so nice too rev limiter and you being able to adj the timing curves ..... really wish I would a spent the extra cash when I got the new ign and coils.
1978 KZ650 b-2
Last edit: 02 Nov 2017 10:21 by KZB2 650.
- zukdave
02 Nov 2017 18:31 #774143
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
I checked my note's and I was wrong it's a 22.5 pilot I went up and now the bike will idle some what right.
The main's I went down one size to the 122.5's but the best change was dropping the needle's two notch and taking
a bunch of part throttle fuel away.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
The following user(s) said Thank You: KZB2 650
- zukdave
04 Nov 2017 08:23 #774210
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
20 Nov 2017 16:39 - 20 Nov 2017 16:41 #774836
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Guess I should update this. The Twist off is a vintage bike event put on by Revival Cycles a local vintage/ antique bike shop
so most bike's there were cafe/bobber style bike some nice resto CB's, XS's some Norton's, Guzzy's Triumph a bunch of old beemer's
Now for the racing part. I got in about 25 pass for the weekend and set low E/T (7.23 my best pass) for the event from what I've been told.
Track prep sucked they didn't need to do a lot for the power most of the bikes made but for me I couldn't get the bike to hook up an spun the tire all weekend and couldn't get out of the 1.80 60 ft's.
I did get to run a few late model 600 class sport bikes and ate their lunch that was fun.
Best run's of the weekend I hooked up with two dude's from a local F/b page one on a 2015 R1 Yammaha and the other on a 2016 S1000RR BMW.
Ran the R1 three time's and got him all three not by much but I got the win light
Ran the BMW twice and got him both time's and was the best racing of the weekend looking back and seeing him coming
he was flying when came around me in the light's. A slow pass for me but here's a slip from one run we did.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Last edit: 20 Nov 2017 16:41 by zukdave.
- zukdave
24 Dec 2017 18:12 #776590
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Man I can't believe I haven't even started this bike since the last time at the track that was almost 2 months ago
I think if it warms up this week I'm gonna get it out for a ride.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- bluej58
- Thank you received: 511
25 Dec 2017 07:27 - 25 Dec 2017 07:28 #776605
by bluej58
78 KZ1000 A2A
Replied by bluej58 on topic Drag strip trip.
We just got snow last night and it is 15 deg. F out side today, and the wind chill it feels like - 1
But that's OK, it's maintenance time....
78 KZ1000 A2A
Last edit: 25 Dec 2017 07:28 by bluej58.
- zukdave
25 Dec 2017 11:50 #776609
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
I'ma blame it on that damn ZRX been takin up all my time.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
22 Apr 2018 00:16 - 22 Apr 2018 00:18 #782150
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Between my job, side work, other project bike's and rain I've only been to the track one time this year and it rained so they called the race but have
been getting in some street riding on it.
Been thinking about swapping the exh. cam for the spare intake cam I've got and see what rhat does for it and try to get in a track day in the
next few weeks
next few weeks
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Last edit: 22 Apr 2018 00:18 by zukdave.
